Suspension & Brakes Theory, alignment, spring rates....
Ground Controls upper and extended upper mount tophat
Old Jul 22, 2005 | 06:15 PM
shyboy817's Avatar
Default Ground Controls upper and extended upper mount tophat
Where can i purchase some GC Upper/or extended mounts, (tophats)? Or is anybody selling a used set of tophat for civic/integras?
Also does anybody have illuminas+skunk2 coilovers combo? If you do, do you have a problem with the fronts sitting on the spring perch / cup whatever the thing is called. My fronts seem to stop about an inch above the cup/spring perch, seems like it was stopped by some sort of ring? The rears sit on the spring perch fine. I'll post up pictures soon.
Old Jul 26, 2005 | 01:09 PM
bretx0r's Avatar
Default Re: Ground Controls upper and extended upper mount tophat (shyboy817)
http://www.ground-control-store.com
Oregonized
Suspension & Brakes
Jul 23, 2007 08:24 AM
el_Presidente
Suspension & Brakes
Sep 16, 2006 03:16 PM
EFSiR
Sep 24, 2003 10:34 PM
AggAccord03
Feb 28, 2002 02:47 PM
