MPFI swap questions - distributor wiring and misc. lines
I started on my mpfi swap today, and I'm about half done with it, but I have a few questions. I need to know how to wire up the distributor, I'm de-pinning the Si pins and using my DX plug, but the colors don't match from one to the other. Here are the wire colors:
Si-
peach
white/red
white/blue
blue/green
blue/yellow
peach/blue
white
DX-
orange/blue
orange
tan
tan
tan/blue
Also, I need a diagram showing where all the lines and hoses go from the dpfi manifold to the mpfi one. I've got a vacuum line diagram, but I need to know where the others go.
Thanks honda-tech you're the best
Modified by crex23 at 3:38 AM 7/24/2005
Si-
peach
white/red
white/blue
blue/green
blue/yellow
peach/blue
white
DX-
orange/blue
orange
tan
tan
tan/blue
Thanks for the link, it's where I got most of my info (including the wiring) from. But I still need to know how to wire up the distributor keeping the DX plug, and a diagram of where the lines and hoses connect from the intake manifold.
More stuff just in case
DPFI to MPFI Fuel Injector Swap Guide #1
http://www.angelfire.com/d20/h....html
DPFI to MPFI Fuel Injector Swap Guide #2
http://www.geocities.com/teampimports/fuelinj.html
DPFI to MPFI Fuel Injector Swap Guide #3
http://www.geocities.com/c_rexboy/mpfi.html
DPFI to MPFI Fuel Injector Swap Guide #4
http://www.bladesilver.net/crx/
DPFI to MPFI Fuel Injector Swap Guide #5
http://www.fourthgenhatch.com/mpfi.html
I've got a question about the banjo fuel line on the DX, it doesn't seem like it will work. The DX manifold has a hole in the side, the Si manifold has a piece on the end of the fuel rail that unscrews. Do I have to buy an Si fuel line, and if so, can I get this piece at Autozone, etc or is it a dealer only part?
About the distributor wiring, I got this from Hcivic88's site. But why is there two sets of blu/yel and blu/grn wires? I need a diagram like this, but maybe I'm just not understanding it?
Be easy on me, this is my first mpfi swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crex23 »</TD></TR><TR><TD CLASS="quote">I've got a question about the banjo fuel line on the DX, it doesn't seem like it will work. The DX manifold has a hole in the side, the Si manifold has a piece on the end of the fuel rail that unscrews. Do I have to buy an Si fuel line, and if so, can I get this piece at Autozone, etc or is it a dealer only part?
Be easy on me, this is my first mpfi swap </TD></TR></TABLE>
as for the fuel line, it is the same i cant see why u are having issues with it....
as for the wiring i dont understand exactly what you are asking, have u checked the links that "4banger69" put?
they also have more diagrams...
you can make the throttle cable work, but it would be good to get one off of a civic with the mpfi, does not have to be an si. also about the fuel. you can dill out the holes an the fuel filter bolts a little bit bigger for more fuel flow, i made both of mine the same size (on one bolt, both holes, on both bolts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwztdSi »</TD></TR><TR><TD CLASS="quote">Not to thread jack but I have a couple of questions..... Is it absolutely necessary to change the ECU and to me it looks like the DX throttle cable is way to long..does it still work? </TD></TR></TABLE>
Yes you have to use a PM6 (or in my case which is auto, a PS9) ecu. The DX ecu is set up to run 2 injectors, not 4. About the throttle cable, mine works fine, when I fired the car up, I had to adjust it a little because it 'idled' at 3k, but now it idles normally.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwztdSi »</TD></TR><TR><TD CLASS="quote"> I'm wanting to keep mine auto as well. can you tell me what car the PS9 ECU comes out of? </TD></TR></TABLE>
The PS9 comes out the the 90-91 Civic EX auto. It is somewhat rare, hard to find, and fairly expensive when you do. I paid $80 for mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crex23 »</TD></TR><TR><TD CLASS="quote">Yes you have to use a PM6 (or in my case which is auto, a PS9) ecu. The DX ecu is set up to run 2 injectors, not 4. About the throttle cable, mine works fine, when I fired the car up, I had to adjust it a little because it 'idled' at 3k, but now it idles normally.</TD></TR></TABLE>
some PM6's came in auto also FYI
they are also found is select EX's
2fast4udude
May 15, 2006 09:56 PM
MaaseyRacer
Mar 19, 2003 10:15 PM
