Timing belt help
I bought a 1993 Honda Prelude Si 4WS a couple of months ago. When i was driving home from work my timing belt broke. It went at exactly 90K miles. I took the head to a mechanic and got it fixed. When i installed the head and belt and started the car the engine shook real fast and then shut off. Today my father started the car and it ran for a while and then it cut off. Now i have no spark. Can anyone help me here?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda3431 »</TD></TR><TR><TD CLASS="quote">Did the mechanic just replace the timing belt? or everything else that went wrong? If your timing belt broke while driving, you probably have bent valves, etc. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpv173 »</TD></TR><TR><TD CLASS="quote">I bought a 1993 Honda Prelude Si 4WS a couple of months ago. When i was driving home from work my timing belt broke. It went at exactly 90K miles. I took the head to a mechanic and got it fixed. When i installed the head and belt and started the car the engine shook real fast and then shut off. Today my father started the car and it ran for a while and then it cut off. Now i have no spark. Can anyone help me here?</TD></TR></TABLE>
That doesn't mean anything... it was a simple question, let him answer. He said he took off the head, why didn't you just bring the whole car in? I had to get mine towed to the shop.
Well it won't start if you don't have any spark I know that for sure. How long is it running? Are you talking like 3 seconds and bam and the plugs are wet. That sounds like a coil or dizzy ignitor for sure. I'd diagnose that first!
When I first built my all motor prelude. On initial startup it would fire and 3 seconds later stall. Only way I could get it to keep running was grab the gas until it got to temp. Turned out to be the ignitor inside the distributor so I'd say yes there's a good chance it's the dizzy!
Ok, here's the deal. I replaced the distributer, distributer cap, rotor, coil, wires and spark plugs and it started for few seconds. The tach went up and down and then it stalled. I tried to restart it and now I have no spark again. Now i'm confused. This car is about to end up in the river!
Modified by rpv173 at 12:38 PM 7/23/2005
Check for spark first.
Old Trick.
The car doesn't have to run. Do this AFTER it dies.
dis-connect the resistor box to the injectors so it doesn't start. (Really doesn't matter though)
Pull a plug wire and the coordinating plug.
push the plug in the end of the wire where it's suppost to be
Touch the Bottom of the plug to a good ground
have someone turn the motor over and see if theres a spark from the plug.
If so, you still have spark and it's probably fuel.
Go from there.
Old Trick.
Go from there.
