Suspension & Brakes Theory, alignment, spring rates....
Lower Conttol arm question
Old Jul 22, 2005 | 05:40 PM
noworldorder's Avatar
Default Lower Control arm question
Does anyone know if integra GSR Lower control arms will fit on a 2000 civic hatch?
I got koni yellows, but for some reason they sent me GSR rears and the mounting point is wider than the stock shock. So I was thinking of buying aftermarket LCA's for a GSR to solve my problem. Also, I bent the stock LCA trying to take off the rear trailing arm assembly- I'm doing a drum to disk swap.
Old Jul 14, 2009 | 02:28 PM
slimm42's Avatar
Default Re: Lower Conttol arm question
good question
Old Jul 14, 2009 | 02:31 PM
phunhaus's Avatar
No. The 90-01 Integra and 88-95 Civic arms are much shorter in length than the 96-00 Civic.
The good news is you can swap the lower shock bushing between them to get the fitment you need.
Old Jul 15, 2009 | 03:11 AM
.Manny.'s Avatar
Touching My Member
x2! Bushing swap FTW!
Rey Cruz
Suspension & Brakes
May 9, 2016 07:55 AM
cnydc2
Aug 9, 2008 05:17 PM
0ptimus prime
17
May 8, 2005 09:35 AM
Jdm93civic
Nov 25, 2003 05:16 AM
