i search but no luck, help with wire
Old Jul 22, 2005 | 04:58 PM
icu_p_p's Avatar
Default i search but no luck, help with wire
okay HT folks, i need to know what wire is the main power for the fuel pump on 98 obd2 (i believe) integra gsr, there are three wires running yellow/white stripe, blue/white stripe, and black/white stripe. i cut yellow wire (that was the fuel guage), i cut blue wire (nothing happen ), black wire is ground correct?
help my teg from these overpopulated theifs. if you're wandering i did search, came up with mostly civic stuff no teg
Old Jul 22, 2005 | 05:04 PM
Racermech's Avatar
Default Re: i search but no luck, help with wire (icu_p_p)
You are trying to install a kill switch??
From what i have read you should be able to hook up the switch to any wire. However it is interesting that the yello cuts the fuel gauge.
Anyways either of the other two wires should dut power when hooked to a switch. Heek up the ground to the switch, if the pump is not grouned it wont work. You can also hook up a kill switch up mear the dash/ecu. I think the wire is yellow with green dash. Can someone confirm or deney this for me.
hellajdm333
16
Feb 20, 2010 02:35 AM
standbackimapro
Audio / Security / Video
Feb 21, 2007 07:38 AM
DarkDragon
Jun 12, 2005 12:03 PM
smokinvtecCRX18
Jun 15, 2003 01:31 PM
VTECAcuraGSR
Apr 10, 2002 12:04 PM
