car shut off while making a turn
Old Jul 22, 2005 | 04:45 PM
hondamama7894's Avatar
Default car shut off while making a turn
As the title says, my car totally turned off while I was making a turn. Earlier before this happened I was stopped, and it acted like it wanted to stall, but didn't. I have a couple ideas what it could be but not too sure. Any help would be greatly appreciated.
Old Jul 22, 2005 | 05:00 PM
SnIpErS-GsR's Avatar
Default Re: car shut off while making a turn (hondamama7894)
Possible vacume leak? I know that vacume leaks make the car almost stall out. Maybe a short in the electrical system somewhere? Anyone work on your car lately?
Old Jul 23, 2005 | 08:03 AM
Reason's Avatar
Was your car low on gas? This use to always happen to me when I was low on gas, but i also had a walbro fuel pump and this is a common thing.
Old Jul 23, 2005 | 08:45 AM
jdm420da6's Avatar
Default Re: car shut off while making a turn (Reason)
does it totally turn of electrically, or does the motor just stall....
if its stalling, do u have a powersteering, if so, do u have a p/s oil leak? or maybe it could be a bad p/s oil pressure switch. when u make a turn the motor likes to die or come close to it cause of the extra stress when u turn, the p/s pressure switch fixes that by telling the ecu to bump the idle a little when u turn. if that switch is bad, it could be causing ur motor to stall.
Old Jul 23, 2005 | 11:33 AM
The motor acted like it wanted to stall earlier in the day at a dead stop, but didn't. It totally shut off all power to the car. So i guess its not really stalling, just shutting off completely.
Old Jul 23, 2005 | 02:05 PM
jdm420da6's Avatar
so no lights stay on in your dash after it dies...?like the check engine light etc..etc...check ur ignition system..or ur ign. switch.
slammed em1
Apr 16, 2010 05:04 AM
stemiched
Jun 12, 2007 10:27 PM
CRX_Control
22
Feb 22, 2005 07:08 PM
turbociv
Jul 14, 2004 01:45 PM
wm5holla
Sep 15, 2003 01:16 PM
