Fluidyne Fan Install
I have a 1994 Integra GSR. I just received my fan and would like to install it. I noticed that the adapter plugs are not the same. How man I suppose to install it? Cut the wires and join them together? If I do that would it be to hot in there to use regular electrical tape? I am not sure what I suppose to do exactly so step by step tips would be really nice.
Thanks in advanced.
Thai
Modified by integraGSR213 at 4:20 AM 7/23/2005
Thanks in advanced.
Thai
You should be soldering connections. Use some shrink tube over it and you'll be fine. Just make sure you don't wire it backwards. That would suck if your fan was going the wrong way.
nevermind the fan does work. The last time my car was in the body shop they must have crossed up the wires because my radiator fan comes on when i press the AC button. has this happened to anyone else and if it did how did u fix it.
