engine rebuild question
Old Jul 22, 2005 | 02:14 PM
adeline's Avatar
Default engine rebuild question
My engine got water logged last night is a flood and I took off the valve cover and the oil looked like mud. All the oil in the oil pan looked like mud the car would start but, smoke and run like **** is their any way to fix it or do I have to rebuild the engine from top to bottom?
Old Jul 22, 2005 | 02:20 PM
EP3_05's Avatar
Default Re: engine rebuild question (adeline)
Try changing the oil first. If it gets better then problem solved. If it doesn't perform both a leakdown and compression test to determine the health of the engine. If the tests come up bad then it is time for a rebuild. My guess since it runs it might be ok since usually when a car gets hydrolocked the rods will bend since they ae trying to compress an incompressible fluid(water)
matmcg
May 9, 2008 08:40 PM
dc4g
Nov 22, 2005 06:27 AM
Tad
Feb 6, 2005 04:15 PM
youngkow
Nov 28, 2002 10:42 AM
