help, power steering on dc2 leaks real bad!!!
Old Jul 22, 2005 | 02:07 PM
dumafu's Avatar
Default help, power steering on dc2 leaks real bad!!!
have any of you ever had your power steering leaking from near the arm of the car. my leak isn't from the rack, its where the rubber booth is and i dont really want to spend 300 to fix it. any advice...thanks
Old Jul 22, 2005 | 02:37 PM
nevamind's Avatar
Default Re: help, power steering on dc2 leaks real bad!!! (dumafu)
If fluid leaking out from the boot, then eventully the rack-n-pinion itself is already leaking.
Old Jul 22, 2005 | 02:40 PM
IntegraB18C's Avatar
Default Re: help, power steering on dc2 leaks real bad!!! (nevamind)
Just get rid of the power streering, you get a better feel for the car.
Old Jul 22, 2005 | 06:17 PM
dumafu's Avatar
Default Re: help, power steering on dc2 leaks real bad!!! (IntegraB18C)
yeah, i took my power steering out for 6 months and did that loop around trick, but it was too hard to steer..the only thing i dont get about the auto to manual steering is the resevoir part..I understand the T ing part, but my powersteering is leaking which defeats the purpose of a resevoir, im assuming the resevoir contains fluid, wouldn't it leak out..it would be a big help if you guys can explain to me bout the resevoir and whats in it and where to buy it thanks or else its 300 i gotta spend and i spent so much already after completing the jdm conversion...thankss
Old Jul 22, 2005 | 08:51 PM
apok's Avatar
Bullshit. My car is easy to handle and all I did was rip out the power steering and put a loop in. Still have the power steering column.
Grey_accord
Jun 17, 2012 10:38 AM
redrocket_ej1
11
Mar 4, 2010 12:09 PM
94c1v1cex
May 21, 2007 05:03 PM
V-Thang
Acura TL, RL & ZDX
May 16, 2005 10:47 PM
