leaking oil from cams on cam gear side
Old Jul 22, 2005 | 12:27 PM
hybrid1990crx's Avatar
Default leaking oil from cams on cam gear side
ok so after discovering my headgasket is leaking...again...I took my head apart and retourqed the head studs hoping to have a quick fix. Well it didnt help, and now after doing so, im leaking oil from my cams on the side of my cam gears. I never put sealant on the cams seals on that side before, and never had a problem. But on reassembling the head, i snapped on the 10mm bolt one on the cam caps, the one closest to the cam gear. Is this why im leaking oil now? This is such a headache now and I really dont ahve time to work on my car.
Old Jul 22, 2005 | 05:12 PM
Default Re: leaking oil from cams on cam gear side (hybrid1990crx)
well i ripped it apart again today and replaced the broken bolt. sealed everything back up with ultra gray and started it once just to make sure the timing was right. only ran it for liek 30 seconds then shut it off to let it sit overnight and seal up. hopefully this fixes the cam leak, ill replace the headgasket next weekend hopefully.
Old Jul 22, 2005 | 08:28 PM
rmcdaniels's Avatar
Did you replace the cam seals?
Old Jul 22, 2005 | 09:14 PM
Default Re: (rmcdaniels)
nah, being in college working part time, and then having my tools stolen has really set me back. i just pulled the head apart and used ultra gray and made sure to torque everything to spec.
Old Jul 22, 2005 | 09:39 PM
Garcia-Racing's Avatar
Default Re: (hybrid1990crx)
should seal up fine
fatdad
Dec 20, 2008 07:30 PM
crxstylin
Mar 20, 2008 12:53 PM
nexgen91
Jul 31, 2007 07:08 AM
user 98292739
Apr 17, 2005 04:21 PM
toooslow
Apr 10, 2003 11:41 AM
