I have a friend up here that doesnt believe that a gsr motor in a rex will hit 13's
Old Feb 18, 2002 | 11:47 AM
LSBeast's Avatar
Default I have a friend up here that doesnt believe that a gsr motor in a rex will hit 13's
Who has a GSR in there crx that has dyno tested it?
Old Feb 18, 2002 | 12:10 PM
TypeR0207's Avatar
Default Re: I have a friend up here that doesnt believe that a gsr motor in a rex will hit 13's (neo0024)
Well, a B16 in one is a mid-high 14 second car with bolt-ons, so why would a GS-R equipped one be a second faster stock??
Old Feb 18, 2002 | 12:15 PM
RenoRacing's Avatar
Default Re: I have a friend up here that doesnt believe that a gsr motor in a rex will hit 13's (TypeR0207)
i have a friend that hit 13.9 in a 92 hatch full interior and with only headers and intake on his gsr.
Old Feb 18, 2002 | 01:06 PM
LSBeast's Avatar
Default Re: I have a friend up here that doesnt believe that a gsr motor in a rex will hit 13's (HavokRacing
Thanks for the info (HavokRacing)
as for you TypeR0207; do the math. Look at the difference in the spec's. From there common sense just might come in to play.
Old Feb 18, 2002 | 02:46 PM
mannyman's Avatar
El Veterano de Sur Califas
well u have to see, what kind of gsr it is....a usdm or jdm. Us one has 170 and the other 180...and the b16a is 160. so if u have a us gsr you will only run like .2-3 faster, so it will only be mid to low 14's. Now if you have a jdm gsr u should be in low 14's or high 13's. and if you are not at sea level u will run slower and might not break into 13's. just really depends on alot of small things, but it is possible.
manny
Old Feb 18, 2002 | 04:33 PM
escocrx's Avatar
its not .2-3 faster from reallife situations ive had.
its much faster than that.
as i have a b16a+tranny JDM.
and im upgrading to b18c1 USDM. gonna build the head before i put her in though. so i'll hopefully be hittin low 13's the day i bolt it in. my b16a just dont cut it. ive driven both in exact setups in cars and most definately will be breakin off all u b16a users .
example:
crxsi 91 + USDM b18c1+b16a JDM tranny. S1 i believe. whichever one has close gear ratios stock clutch. = 13.988 1/4
crxsi91 + JDM b16a+same tranny and stock clutch.. = 14.5 1/4
both full interior. both on stock 14inch 91 si rims.
all the normal bolt ons.
and dont git me wrong. my b16 pulls nice. but for less $$$ i can make my USDM b18c1 faster.
just what ive seen. every setup is different.
Old Feb 18, 2002 | 05:49 PM
mannyman's Avatar
do u personally know of someone with a usdm gsr in a crx that hit a 13.9??? if so i would like to know what ecu is he using.
Old Feb 18, 2002 | 07:50 PM
escocrx's Avatar
exactly i dunno. it is a gsr ecu. reprogrammed wit what instructions i dunno.
type r manifold. port matched TB and intake ports, i, h, e
otherwise stock.
no cams. or anything else done to it.
Old Feb 19, 2002 | 04:00 AM
TypeR0207's Avatar
And that is the key, I said BONE STOCK, I could make a GS-R'ed CRX run low 13's with bolt-ons ...... same thing I can do with a B16 (cams are bolt-ons by the way).
Newb telling ME how fast a car can run ........ I don't see HIM getting a Type R into the 13's with stock cams, compression and internals .........
[Modified by TypeR0207, 8:01 AM 2/19/2002]
Old Feb 19, 2002 | 09:39 AM
WuShu's Avatar
New User
"Newb telling ME how fast a car can run ........ I don't see HIM getting a Type R into the 13's with stock cams, compression and internals ......... "
You tell him mang, "TypeR0207 ownz joo!"
Old Feb 19, 2002 | 11:26 AM
ghettols's Avatar
hmmm...back in the day, my cousin's crx hit 14.0's consistent....his setup was a stock gsr motor, (no work done yet) some semi slicks that were pretty bad,suspension sucked and unlightened car. i'm pretty sure its possible
Old Feb 19, 2002 | 05:36 PM
SiREF8's Avatar
I say high 13's are possible w/slicks, Z10 radius rod kit and a good driver.
johnnyb17
Jan 16, 2012 01:30 PM
VRD^sam
Oct 11, 2005 11:04 AM
ekdriven
Feb 15, 2005 09:25 PM
Resurgent
Sep 6, 2002 10:20 AM
B18CXr
May 30, 2002 12:10 PM
