civic swap map/idle probs still
Old Jul 22, 2005 | 12:07 PM
5thGenFanatic's Avatar
Default civic swap map/idle probs still
hi..i am posting this in a couple forums other than where it should be because noone else seems to be able to help me...i would like to see if someone from the delaware area (northern) would be willing to stop by sometime and help me figure out what is wrong with my car...ive already tried the suggestions thing on here to no avail.. i need a really good person willing to stop over..if you can help me figure out what the problem is ill give u like a hundred bucks...im having map issues with a swap i did from my integra to my civic...jdm motor, gsr trans, complete harness, no splices or cuts at all...ecm..basically a direct swap..ran fine for a year in the teg..ive tried everything..its throwing a code 3 and idle wont drop from 1400 even when warm...i tried vacuum checks and leak checks, 3 map sensors, spare ecm, cleaning all the connectors, iac and tps just for the hell of it...not fixing..need help.going nuts..wanna get back to track....PLEASE SOMEONE GOOD!!!!!..... my email is LoradoLr@aol.com..
Old Jul 22, 2005 | 05:30 PM
slomofo's Avatar
GDD Member
Just a shot in the dark, have you tried swapping throttle bodies?
Old Jul 22, 2005 | 08:03 PM
eda6's Avatar
Default Re: (slomofo)
have you ohmed out the map sensor circuit? Made sure all the wires are landed in the correct pins at the ecu?
Old Jul 22, 2005 | 08:09 PM
slomofo's Avatar
GDD Member
Nobody here knows your problem, but i'm sure that when you do find the problem it's going to be something sooooooooo stupid you just want to kick yourself, something like a throttle body gasket or low coolant level...either way, good luck to you.
Old Jul 26, 2005 | 01:02 PM
bump
5thGenFanatic
Jul 28, 2005 10:16 AM
5thGenFanatic
Jul 26, 2005 03:56 PM
5thGenFanatic
Jul 26, 2005 01:05 PM
5thGenFanatic
Jul 26, 2005 01:03 PM
5thGenFanatic
Jul 26, 2005 01:00 PM
