Question about koni revalve
Ive been reading quite a bit lately about the Koni/GC combo and Im pretty set on the combination. My question is at what point (rate) would it be wise to revalve the yellows? I havn't really found a clear-cut answer on here in my searches. The best Ive come up with is 450/550 as the limiting rate (anything above it is wise to revalve, anything below you are fine stock). Does this sound right? Would I be able to run 450/550 safely, without worry of reliability issues?
If I missed something searching, just give me a link. Thanks for any help.
It's my opinion that 550# was the limit for my Koni Sports. I drive a 4-door Integra so YMMV. I switched to double adjustable and shortened Konis and can't be happier.
To clarify, I had heard the 550 was the limit as you said. I had just thought running 450/550, and so was wondering if this would be safe. Thanks for the response, hopefully alot more are coming. Lunch bump from a bored federal employee
i'm running 450/550, so far so good.
the limit is not set in stone, in conversations with Lee, he's said it's somewhere around 600#/in, IIRC.
the shock will definitely handle the spring better with a revalve at those rates, so it might be worth it to revalve anyway, but as far as NEEDING to, i don't think it's a necessity.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -_- »</TD></TR><TR><TD CLASS="quote">So it would seem then that I would be better off buying used ones and getting them revalved than buying new and doing so, correct? </TD></TR></TABLE>
Yeah, that would be the smart way to go if you know you're going to get them revalved.
i would also think about getting them shortened a touch too?
92integraVTECgsr
Suspension & Brakes
Mar 14, 2008 11:47 PM
Junkyard2000
Jun 14, 2005 09:29 PM
MeanGreenEG9
Feb 14, 2003 03:01 AM
