What are real HID's
Old Jul 22, 2005 | 04:31 AM
94Vtecluder's Avatar
Default What are real HID's
I'm mulling over getting HID low beams for my JDM headlights. First off what are all these HID conversion kits I keep seeing on ebay? Is this a real HID kit right here.
http://cgi.ebay.com/ebaymotors...wItem
Even tho my Car is USDM and my wiring harness are wired for 9006/9007 I would still want to get a H4,H1 conversion kit cuz those are the ones that will fit the headlight right? I mean I'm going to have probaly splice some wires so I might as well H1/H4 right?
Old Jul 22, 2005 | 04:39 AM
red92s's Avatar
Default Re: What are real HID's (94Vtecluder)
Spend the extra money and do a projector retrofit
Old Jul 22, 2005 | 04:43 AM
Default Re: What are real HID's (red92s)
Aww man I specifically didn't get projectors cuz I thought they were ricey. The JDM headlights don't project enough? What's the difference?
Old Jul 22, 2005 | 04:54 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">Aww man I specifically didn't get projectors cuz I thought they were ricey. The JDM headlights don't project enough? What's the difference?</TD></TR></TABLE>
Wow... He meant retrofit some H.I.D projectors from a bimmer or something into your headlights... Not buy ricey projector headlights... god damn...
Old Jul 22, 2005 | 05:16 AM
red92s's Avatar
1. register at http://www.hidforum.com
2. read this: http://hidplanet.com/forums/viewtopic.php?t=2080
3. read this: http://hidplanet.com/forums/viewtopic.php?t=3505
4. read this: http://hidplanet.com/forums/vi...elude
A little research will go along way towards making sure you are happy with the end result of your project.
Old Jul 22, 2005 | 05:36 AM
Okay last question, do the H1/H4 bulbs look any more HIDish than the standard 9006/9007?
Old Jul 22, 2005 | 05:39 AM
red92s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">Okay last question, do the H1/H4 bulbs look any more HIDish than the standard 9006/9007?</TD></TR></TABLE>
Sure, if you buy some "HYpeR BluE" bulbs off ebay the color might be closer, but the ouput will still not be anywhere close (regardles if you are running H1's, H4's, 9006, or 9007)
Old Jul 23, 2005 | 04:27 PM
hondaren's Avatar
Well most of the HID kit are real HID, but you need to be beware of the quality of those Crap Chinese/Taiwanese made HID.
My roommate bought a set from those Chinese made HID, works only for 3 weeks and there are lots of problems.
Therefore you should try somewhere with bettter quality, such as Real Hella or PHILIPS HID kits, although the price is much higher.
I got my set from http://www.hidynamic.com, they are selling the rebased Hella HID kits, the ballasts are made in Korea under a German production line and the bulbs are made in Japan. The quality of the lighting is really good.
I am thinking about adding the HID on my foglight too, still saving money right now.
Old Jul 23, 2005 | 04:41 PM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">I'm mulling over getting HID low beams for my JDM headlights. First off what are all these HID conversion kits I keep seeing on ebay? Is this a real HID kit right here.
Even tho my Car is USDM and my wiring harness are wired for 9006/9007 I would still want to get a H4,H1 conversion kit cuz those are the ones that will fit the headlight right? I mean I'm going to have probaly splice some wires so I might as well H1/H4 right?</TD></TR></TABLE>
Don't get any of that ****. In the case of a 4th gen (yours) get either E46 BMW projectors and bulbs (what i'm doing) or...I believe audi a4 projectors also fit. Then, disassemble your headlight housings and mount the projectors in your headlights.
By doing this, you won't have any of these stupid rebased bulbs (like what's being sold in the kit). You'll have actual (I belive D2S or something) bulbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaren &raquo;</TD></TR><TR><TD CLASS="quote">Well most of the HID kit are real HID, but you need to be beware of the quality of those Crap Chinese/Taiwanese made HID.
I am thinking about adding the HID on my foglight too, still saving money right now. </TD></TR></TABLE>
No need to be racist about it. The reason they're crappy is not because the manufacturers are Chinese. The company itself is garbage. Buying from a proper company is more important than buying from the right country. I'm sure Korea, Germany and Japan all produce crappy things as well.
That said, Hella and Philips (sp?) are the best kits to buy. When you buy HID conversion kits like those advertised on the site you mentioned, you are buying rebased HID bulbs which will fit in halogen housings. This is not what you want. Halogen housings are designed for the light output of halogen bulbs. By placing HID bulbs inside the halogen housing, way too much light is scattered around, and it blinds people. This is why HIDs in non-HID-spec cars are illegal. Projectors, such as those found in BMWs, Audis, and the like, produce a clean cutoff line which prevents the light from your car from getting into other peoples' eyes.
Old Jul 23, 2005 | 05:55 PM
NAiL05's Avatar
Default Re: What are real HID's (The Phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil &raquo;</TD></TR><TR><TD CLASS="quote">
Don't get any of that ****. In the case of a 4th gen (yours) get either E46 BMW projectors and bulbs (what i'm doing) or...I believe audi a4 projectors also fit. </TD></TR></TABLE>
My friend used E39 Head lights and bulbs and retrofitted it into his Lexus GS300. Plus retrofitting will allow you not to blind the **** out of other people when your driving and police wont get on your *** about it.
Old Jul 23, 2005 | 06:49 PM
PrettyLude's Avatar
do a retrofit with bixenon projectors, that way you can have hi and low beam hids
Old Jul 23, 2005 | 08:06 PM
The Phil's Avatar
Default Re: What are real HID's (NAiL05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 &raquo;</TD></TR><TR><TD CLASS="quote">My friend used E39 Head lights and bulbs and retrofitted it into his Lexus GS300. Plus retrofitting will allow you not to blind the **** out of other people when your driving and police wont get on your *** about it.</TD></TR></TABLE>
I was talking about retrofitting...
Old Jul 23, 2005 | 08:37 PM
hatchyback's Avatar
dont listen to hondaren..
HE IS ACTUALLY THE PERSON WHO RUNS HIDYNAMICS SO HE IS HUSTLING all of you guys RIGHT NOW into buying his kits, DO NOT LISTEN TO HIM!
my friend bought a couple sets from him back a while ago and he never warrantied them, claimed that he was still in china or whatever BULLSHIT he came up with
its people like you eric or "auric" that give HID's a bad name
Tsunami
15
Oct 11, 2006 06:10 PM
BB1vtec
Jul 8, 2006 05:13 PM
White V6
Apr 3, 2006 07:35 PM
jdmeg9
Dec 7, 2005 08:48 PM
pnoi_01dc2r
Aug 24, 2005 08:17 AM
