Turbo insulation kits/wraps
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Has anyone here have used them? Or have any experience with them?
I've been seeing them around and wondering how effective they are.
Insulating wraps like the one on the link below.
http://store.summitracing.com/...earch
Yeah, the thermo-tech one. The blanket works good for awhile. Then it discolors and eventually falls apart. The fiberglass wrap is good, but it gets so brittle after a while that you can't touch it without scraping some of it off.
These are basically race products. You can't buy them expecting them to last more than 20,000 miles.
Now, these blankets are nice:
http://cgi.ebay.com/ebaymotors...=WDVW
20,000 miles seems pretty decent to me. I only drive about 5000-7000 miles a year. If that turbo wrap last 3 years before I need to replace them, that would seem pretty okay with me. 100 bux every 3 years isn't so bad.
Question: By wrapping the turbo, you help lower under-hood temps. Is that basically the only point of a turbo-wrap?
I've seen the claim "helps spool up faster", but still not sure how the wrap is going to help with that.
What about heat-soak? Are you going to do damage to your turbo over time by not letting it radiate the heat?
some of those descriptions for the heat wrap on the turbo say turbos run better when they are hot, which sounds like bullshit. I have the black fiberglass exhaust wrap on my DP, which is now brown and falling off after like 5 months of driving. It does insulate very well though, I can touch it after like an hour of driving and it wont melt off my fingerprints.
combustion
Feb 19, 2008 11:15 AM
CHEETAH
Jan 16, 2005 07:25 AM
dynomax27
Nov 13, 2002 07:41 PM
