ACL out of spec, need oem GSR main
Old Jul 21, 2005 | 11:40 PM
Ek-CoolGuy's Avatar
Default ACL out of spec, need oem GSR main
I have a set of ACL std bearings for my GSR build.
I plastigauged the mains first.
#1 is out of spec. Using a micrometer it measured out to .0023 which is outside of the oem .0011-.0021 tolerances.
I will replace this single bearing with an oem unit, the question I pose is which color bearing do I need?
Thanks in advance
Old Jul 21, 2005 | 11:44 PM
Ek-CoolGuy's Avatar
Default Re: ACL out of spec, need oem GSR main (Ek-CoolGuy)
#2-#5 were exactly .0015 btw....
Old Jul 22, 2005 | 10:23 AM
IN VTEC's Avatar
I'd try a blk or blu.
Old Jul 22, 2005 | 12:09 PM
Ek-CoolGuy's Avatar
Default Re: ACL out of spec, need oem GSR main (IN VTEC)
thanks for chiming in IN VTEC, however, the bearing wasnt out of spec! I cleaned all of the threads of the bolts and lubed them.
#1. .0015
#2 .0015
#3 .0020
#4 .0015
#5 .0015
NOTE TO SELF: clean and lube threads on bolts for accurate torque readings!
Old Jul 22, 2005 | 06:03 PM
EHondaD6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek-CoolGuy &raquo;</TD></TR><TR><TD CLASS="quote">thanks for chiming in IN VTEC, however, the bearing wasnt out of spec! I cleaned all of the threads of the bolts and lubed them.
#1. .0015
#2 .0015
#3 .0020
#4 .0015
#5 .0015
whoa! this is very important good thing you did it
tepid1
Feb 10, 2007 04:32 AM
wascly
Jul 9, 2006 04:35 PM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
cueballsi
Jan 30, 2005 04:47 AM
