V-TEC for '92 Honda Accord
Old Jul 21, 2005 | 10:31 PM
Cimby's Avatar
Default V-TEC for '92 Honda Accord
In the next couple months I will be looking for a new engine for my 1992 Honda Accord. It is completely stock right now and I want to put a V-TEC. I am planning on searching junk yards for cars that have been totalled but the engine is still good. Anyone know anywhere in Washington that is a good place to look or know where I can get one for a couple grand or cheaper? I also need to know what other new parts I'll need to put in to support the engine. Like I said, its a stock 92 accord and I want to change that. I am thinking of putting NOS or a supercharger on it in the future too. Any help would be greatly appreciated.
Old Jul 21, 2005 | 11:56 PM
skinnye's Avatar
Default Re: V-TEC for '92 Honda Accord (Cimby)
why not work with what you have? click on the link to see what I did to my 93
http://www.homemadeturbo.com/f...501.0
Old Jul 22, 2005 | 12:11 PM
NAiL05's Avatar
Yep you can turbo ur f22a which isnt a bad route..its gonna be hard finding a VTEC motor in a junkyard nowadays. You might be able to pull F22B1 out of junkyards out of wrecked accords but i dunno how there condition will be.
Old Jul 25, 2005 | 06:58 AM
Cimby's Avatar
Default Re: V-TEC for '92 Honda Accord (skinnye)
I have been looking at the pictures but I can't tell exactly what you have done. I see an air intake system of some sort but that is all I can see. What else have you done?
Old Jul 25, 2005 | 07:01 AM
Cimby's Avatar
Default Re: (NAiL05)
How hard will it be to turbo the f22A and if I do find a VTEC or good condition f22B1, how hard will they be to put in. I'd like to do it myself, but I really don't have the equipment nor the knowledge so I'll probably just take it to a mechanic unless its really easy but I have high doubts it is.
Old Jul 25, 2005 | 10:08 AM
accordselux's Avatar
Me Gusta History
Default Re: (Cimby)
Dropping a VTEC F series will bolt in just like a Non VTEC F series. All you ahve to worry about is wiring and ECU and the VTEC solenoid
Old Jul 27, 2005 | 02:56 PM
NAiL05's Avatar
Default Re: (Cimby)
Its not that hard boostin an f series. its a good motor to boost with the 8.8:1 compression if i remember. Usually ppl use a 1g DSM setup. If you check out http://www.cb7tuner.com they have a bit of 4gen with the turbo F series.
Old Jul 27, 2005 | 03:45 PM
91 VTEC akkord's Avatar
i have a 91 ex 4 door. i just put a SOHC VTEC out of a 95 accord ex. only mods to the engine is cai and exhuast. purchessed it from a wreaking yard close to you. called "u-fix-it" its in woodinville off HWY 9. any how bought the engine and all nessary parts for about $250.00. then about $800.00 for the install. then HMT wired it up for another $300.00. lots of fun to drive. but am in the process of boosting. good luck with whatever choice you make.
Old Jul 28, 2005 | 02:29 PM
Cimby's Avatar
Default Re: V-TEC for '92 Honda Accord (91 VTEC akkord)
Is your accord a manual? Did you have to switch any of that around at all?
Old Jul 28, 2005 | 07:03 PM
Tha Colonel's Avatar
i did the same swap and mine was an auto but i changed it to a straight drive but you can do that swap easy but it is tricky to wire up the intake but you will be all right
bruceav
Nov 8, 2007 10:21 AM
brendon1989
Jul 18, 2007 02:25 PM
