Got tire changed now a noise
Old Jul 21, 2005 | 10:29 PM
gsr-2nr's Avatar
Default Got tire changed now a noise
I just got my rear tire replaced due to hitting a nail. Well i pick it up from the shop right before they closed because that was the only time i could get there. well anyway im riding home and there is this weird noise sounds like its comming from the rear sprocket like something is rubbing . I checked all the bolts on the sprocket, as well as the axle nut and they were fine but i have no clue what the noise is. Any thoughts of what it is
Old Jul 21, 2005 | 10:51 PM
marmaladedad's Avatar
Is your chain too loose? Check the slack on it. Once, my chain was clanging against my exhaust. I don't think your bike has the exhaust routed near the chain, but you never know...
Old Jul 21, 2005 | 11:07 PM
gsr-2nr's Avatar
Default Re: (marmaladeboy)
I will check that, Thanks
Old Jul 22, 2005 | 04:11 AM
Luke's Avatar
Default Re: Got tire changed now a noise (gsr-2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">I just got my rear tire replaced due to hitting a nail. Well i pick it up from the shop right before they closed because that was the only time i could get there. well anyway im riding home and there is this weird noise sounds like its comming from the rear sprocket like something is rubbing . I checked all the bolts on the sprocket, as well as the axle nut and they were fine but i have no clue what the noise is. Any thoughts of what it is</TD></TR></TABLE>
Go over the back end completely, fxckin bike shops are staffed by morons 90% of the time. Could be chain tension could be a loose mount or something else very bad. Had a mate years ago who had his rear caliper fall of after they left it loose, totaled his RG500. They got taken for a lot of money but thats not the point.
If a jobs worth doing its worth doing yourself.
Old Jul 22, 2005 | 08:26 AM
Willybeen's Avatar
make sure all the internals to the bearings were replaced correctly...... be careful.... an accident as a result of shitty mechanical maintainance is shitty..... i know
Old Jul 22, 2005 | 12:47 PM
Lewdin' Incognito's Avatar
Default Re: (Willybeen)
How about the tire itself? Seems unlikely, but if they put the wrong one on/did some bad stuff to it, it could be rubbing.
Old Jul 22, 2005 | 01:25 PM
CXHatchback's Avatar
Default Re: (Lewdin' Incognito)
I did the same thing myself once and saw metal shavings near the axle, I think I put something back on the wrong order but anyway you want to check that out before riding anywhere else.
Old Jul 23, 2005 | 08:49 AM
wtf mate's Avatar
just go back and tell them they fucked somethign else and ask for the head tech to look it over. thats what i had to do once.
Junior1023
Oct 29, 2013 04:05 PM
94civicx
May 25, 2004 10:33 AM
hecklervtec
Apr 8, 2004 09:41 AM
h22mark
Nov 1, 2003 05:25 PM
