91 teg, clutch pedal hit the floor!!???
Old Jul 21, 2005 | 09:16 PM
DAmn's Avatar
Default 91 teg, clutch pedal hit the floor!!???
So i just replaced my tranny with a b16 ys1 and an exedy organic clutch. Its been 4 days and everything was fine till i was driving and went to shift into third normally and the pedal hit the floor, wtf??? I have narrowed it down to the cable or the pressure plate failing, anyone know what this could be? TIA
Old Jul 21, 2005 | 09:43 PM
DAmn's Avatar
Default Re: 91 teg, clutch pedal hit the floor!!??? (DAmn)
Has anyone else had problems with thier clutch cable in thier da's like this??
Old Jul 22, 2005 | 12:32 AM
RHDintegXsi's Avatar
have you checked the clutch cable? maybe it was installed incorrectly..double check and make sure its on right with the correct tension
Old Jul 22, 2005 | 07:05 AM
MoonScryer's Avatar
^^^^^ is right. Usually such an issue is the tension is not set right on the clutch cable. Check it and you should be golden. If not, drop the tranny out, check the throwout bearing; might be sticking or not on correctly.
Old Jul 22, 2005 | 07:20 AM
DAmn's Avatar
Default Re: (MoonScryer)
if the clutch cable was not installed properly would it have a tendency to just quit working like that? i really dont want to have to drop the tranny again so hopefully i can get it straightened out.
Old Jul 22, 2005 | 04:05 PM
DAmn's Avatar
Default Re: (DAmn)
well i went out this morning to find that it was just the cable that broke, im glad it was only that
groundedcivic91
Jul 17, 2006 03:04 PM
ninjaturtle1023
Jul 10, 2004 03:29 AM
GooD moToRs
Jun 27, 2003 02:33 AM
