valve adjustment tool.
http://www.amazon.com/exec/obi...&s=hi
Won't this work too? Cheaper alternative to the snap-on tool.
You don't need the snap-on tool for a 91 B18A, the jam nuts are much easier to get to then a vtec (b18c) motor, so all you will need is a closed end 10mm wrench and a flathead screwdriver. If you were doing a b18c, those screwdriver/socket combo tools work well because of the angle you need to work with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr »</TD></TR><TR><TD CLASS="quote">You don't need the snap-on tool for a 91 B18A, the jam nuts are much easier to get to then a vtec (b18c) motor, so all you will need is a closed end 10mm wrench and a flathead screwdriver. If you were doing a b18c, those screwdriver/socket combo tools work well because of the angle you need to work with.</TD></TR></TABLE>This is true! But lucky for me I have that tool. But I also have a gs-r so I kinda needed it. Adjusting valves without it sucks.
redDAinteg
Sep 10, 2007 06:50 PM
