will 94+ integra inercooler piping fit 92+ civic ? searched
Old Jul 21, 2005 | 07:23 PM
darrinbrewer's Avatar
Default will 94+ integra intercooler piping fit 92+ civic ? searched
didnt find a stragiht answer, have the turbonetics bolt on kit for 94ls (for sale here for $1750 brand new) does anyone know for sure, that the IC piping will fita 92-5 civic?
i'm guessing since the integra piping goes under the fram rail and up next the the ac lines it would workon a civic
but a civics piping would not work on a integra, because they run it up through the factory air intake hole, i know poeple with b series swaps use aem cold air's made for a integra, they fit that way, so wouldn't IC piping work that way?
Old Jul 21, 2005 | 07:24 PM
SHystrdyGSRtdy's Avatar
Default Re: will 94+ integra inercooler piping fit 92+ civic ? searched (darrinbrewer)
some people run through where the airbox would be, some run the pipe the other way (charge pipe)...
Old Jul 21, 2005 | 07:35 PM
Default Re: will 94+ integra inercooler piping fit 92+ civic ? searched (SHystrdyGSRtdy)
yeah i know that, but will integra piping thats made to run under the framrail and straight up then over the tranny..fit with little or no monification?
Old Jul 22, 2005 | 02:22 PM
swapit's Avatar
i had a complete drag3 turbo kit and it worked on my eg with no problem.the intercooler piping went around and over the trans then into the ic with out any cutting.the kit did come off an 95gsr.
Old Jul 22, 2005 | 04:15 PM
i can refer you over to:
https://honda-tech.com/zero...99328
Phil (from spoolin performance)
he makes/does that type of work... you can him about it
Old Jul 22, 2005 | 04:50 PM
Thurman Merman's Avatar
If you're upper charge pipe angles towards the pass. side fender where the hole is for the stock air boxes on EG, then yes, it will work. But more than likely with the 94+ integra turbo kits, the upper charge pipe goes down by the tranny/radiator and that WILL NOT work with your civic.
All of the other charge piping should work (around each side of the radaitor support and up to the compressor housing).
TunersTown
Jan 4, 2009 11:54 AM
used2baracer
Apr 27, 2006 10:13 AM
theEGkid
Jul 19, 2005 08:58 AM
ThePro
Sep 27, 2004 05:50 PM
