Wiring ex o2 sensor in VX problems...
Old Jul 21, 2005 | 06:45 PM
dturbo's Avatar
Default Wiring ex o2 sensor in VX problems...
I followed a diagram on here on how to directly wire my o2 sensor to my ecu. I chose to wire directly to my ecu because my VX harness is kinda sloppy so it makes it easy on me to wire to the ecu. I'm using a VX harness on my EX motor. Problem is, the wires that I'm suppose to plug into are not the same color as the diagram says. I plugged the o2 up to the wires anyways because they were in the correct slots but i still get the check engine code for my o2. I tried 2 different o2 sensors and no luck at all. Any ideas?
Old Jul 22, 2005 | 09:04 PM
dturbo's Avatar
Default Re: Wiring ex o2 sensor in VX problems... (flyazzcivic)
someones got to have wired an ex o2 using vx wire harness....
Old Jul 23, 2005 | 04:20 AM
EE_Chris's Avatar
What diagram/link/thread did you use from here?
Old Jul 23, 2005 | 08:47 AM
specv5150's Avatar
Default Re: Wiring ex o2 sensor in VX problems... (EE_Chris)
if you used the knowledge base write up, it should work. That is the exact write up I used substituting the OBD1 wire colors for my OBD2 colors from the helms...works great
Old Jul 23, 2005 | 08:58 AM
poison's Avatar
I'm not sure which O2 sensor you're using whether it's Denso or Bosch.
But, here's the pinouts:
White > White > to D14 (O2 Input)
Green > Green/White > D22 (Sensor Ground)
Black > Org/Blk > A6 (Heater Control)
Black > Yel/Blk > A25 (Sensor Positive)
Good luck.
Old Jul 25, 2005 | 06:55 PM
dturbo's Avatar
Default Re: Wiring ex o2 sensor in VX problems... (poison)
That's what I used as a reference but didnt work. I'm using the OEM EX o2 sensor that came on the EX motor...The D14 wire on the ecu isnt WHITE...should it still work? I plugged one of the blk to A25, the other black i plugged to A6 which was not ORANGE/BLACK at the ecu...hrrmm...does green just hook to any ground?
Old Jul 26, 2005 | 03:17 AM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyazzcivic &raquo;</TD></TR><TR><TD CLASS="quote">That's what I used as a reference but didnt work. I'm using the OEM EX o2 sensor that came on the EX motor...The D14 wire on the ecu isnt WHITE...should it still work? I plugged one of the blk to A25, the other black i plugged to A6 which was not ORANGE/BLACK at the ecu...hrrmm...does green just hook to any ground? </TD></TR></TABLE>
-wht/red wire - white wire on where the stock 5 wire was located
-grn/blk wire from donor plug to A6 heater ground ECU pinout.
-sensor gorund to one of the thermostat hosuing wires
-12v switched to the #4 injector yel/blk wire
vxtirent08
Apr 15, 2008 10:15 AM
EGJason
Apr 28, 2007 06:22 PM
dturbo
Jun 8, 2005 06:16 PM
splitime
Sep 7, 2002 07:27 PM
bronzehatch
Jul 11, 2002 07:27 AM
