coil on plug problem PLEASE HELP
Old Jul 21, 2005 | 06:02 PM
dragsol's Avatar
Default coil on plug problem PLEASE HELP
I have a 96 civic with an AEM EMS, M&W ignition box, honda motorcycle coils, and Tony1 hall effect sensor. The car starts,idles and revs up as it did before but the Aem shows that car is running half of the RPMs that the tach is showing. Could someone please give me some help because I really want to run my hometown NOPI race in St. louis this weekend. thanks for any help.
Old Jul 21, 2005 | 06:49 PM
Boostfed's Avatar
New User
Default Re: coil on plug problem PLEASE HELP (dragsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragsol &raquo;</TD></TR><TR><TD CLASS="quote">I have a 96 civic with an AEM EMS, M&W ignition box, honda motorcycle coils, and Tony1 hall effect sensor. The car starts,idles and revs up as it did before but the Aem shows that car is running half of the RPMs that the tach is showing. Could someone please give me some help because I really want to run my hometown NOPI race in St. louis this weekend. thanks for any help.</TD></TR></TABLE>
PM JDogg, he will HELP YOU OUT!!!!
EDIT: I called JDogg and explained yoru problem, he says you have the Hall Effect sensor backwards, you have the cam and crank trigger wired backwards. Fix those and you wil be good he said.
Old Jul 21, 2005 | 06:59 PM
dragsol's Avatar
Default Re: coil on plug problem PLEASE HELP (Boostfed.com)
Thank you that will be what I try next.
Old Jul 21, 2005 | 08:22 PM
tony1's Avatar
Check the number of crank trigger teeth in the software, you have to remember that since it's on the cam, it only turns at half engine speed. If it's asking for crank pulses per REVOLUTION, then it's 6, if it's asking for crank pulses per CYCLE, then it's 12. I think you have 6 in there when it wants 12? If you had the wires backwards, it shoudn't run and should be off way more than half engine speed.
Old Jul 21, 2005 | 09:46 PM
JDogg's Avatar
Default Re: coil on plug problem PLEASE HELP (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Check the number of crank trigger teeth in the software, you have to remember that since it's on the cam, it only turns at half engine speed. If it's asking for crank pulses per REVOLUTION, then it's 6, if it's asking for crank pulses per CYCLE, then it's 12. I think you have 6 in there when it wants 12? If you had the wires backwards, it shoudn't run and should be off way more than half engine speed.</TD></TR></TABLE>
yeah, that too... i was ASSUMING you had it setup in the software properly.
the honda base calibrations are setup for 24 teeth, not 12. you will need to go through every option that deals with "teeth" and cut it in 1/2...
Old Jul 22, 2005 | 08:28 AM
AEM DP's Avatar
Default Re: coil on plug problem PLEASE HELP (JDogg)
dragsol - I just talked to Mark at Tydo. I gave him the info you need.
The wiring should be fine as well as the tooth options.
Modified by Devin@AEM at 9:43 AM 7/22/2005
Old Jul 22, 2005 | 09:02 AM
Boostfed's Avatar
New User
Default Re: coil on plug problem PLEASE HELP (Devin@AEM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devin@AEM &raquo;</TD></TR><TR><TD CLASS="quote">dragsol - I just talked to Mark at Tydo. I gave him the info you need.
Modified by Devin@AEM at 9:43 AM 7/22/2005</TD></TR></TABLE>
Old Jul 25, 2005 | 06:03 PM
dragsol's Avatar
I would like to thank everyone for all of the help that I have gotten on trying to get my car going. Devin, Mark is suppose to get ahold of you to figure out why the car wont rev past 5500 RPM. I really appreciate all of the time that you have spent with us.
jonwtsb
Engine Management and Tuning
Sep 26, 2011 06:59 PM
Boosteddb8
Jun 15, 2008 03:53 PM
NaStY CoUpE
Mar 9, 2008 06:50 PM
redex04
Jul 27, 2007 06:43 AM
slowsi00
Sep 7, 2002 03:16 AM
