need help with my Safc. pro's only :p
Old Jul 21, 2005 | 05:48 PM
RACEPAK's Avatar
Default need help with my Safc. pro's only :p
hello everybody....
i just finished installing my safc on my D14a4 and its not responding.
i didnt tryed to cranck the car but i put the key on "on" and nothing.....
can somone please check if i wired it OK ?
this is how i wired it:
RED/POWER - pin 13 on connector A
GREEN/RPM SIGNAL -pin 21 on connector A
GRAY/TPS - pin 6 on on connector D
BROWN and BLACK/GROUND as shown - pin 15 on connector A
YELLOW and WHITE/PRESS SIGNAL as shown - pin 7 on connector D
This is the digram of the safc:
this is my ecu:
connector A:
connector D:
thank you for looking in my thread
best regards moshik galimidi
Old Jul 21, 2005 | 09:21 PM
RACEPAK's Avatar
Default Re: need help with my Safc. pro's only :p (RACEPAK)
please help me guys... i really need your help on this one.
Old Jul 22, 2005 | 06:42 AM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">please help me guys... .</TD></TR></TABLE>
Old Jul 22, 2005 | 06:57 AM
menkio's Avatar
bump, somebody help him...
Old Jul 22, 2005 | 06:59 AM
boonacka's Avatar
Default Re: need help with my Safc. pro's only :p (menkio)
when you turn car "on" does anything else come on? (clock, radio, dash lights, etc?)
Old Jul 22, 2005 | 07:04 AM
EE_Chris's Avatar
What isn't 'responding' about it?
RACEPAK's Avatar
Default Re: need help with my Safc. pro's only :p (boonacka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">when you turn car "on" does anything else come on? (clock, radio, dash lights, etc?)</TD></TR></TABLE>
yup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote">bump, somebody help him...</TD></TR></TABLE>
Old Jul 22, 2005 | 07:33 AM
boonacka's Avatar
check power wire with a voltmeter to make sure theres actually power there.
Old Jul 22, 2005 | 02:06 PM
RACEPAK's Avatar
Default Re: need help with my Safc. pro's only :p (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">What isn't 'responding' about it?</TD></TR></TABLE>
its not turning on
Old Jul 22, 2005 | 02:13 PM
dustin's Avatar
What ECU do you have? (i.e. what OBD is your harness)
Old Jul 22, 2005 | 02:23 PM
RACEPAK's Avatar
Default Re: need help with my Safc. pro's only :p (dustin)
im assuming its obd2
-car is made in 97'.
-obd2 injector clips.
the ecu called "P3Y"
i know a guy that allredy used a safc on this ecu. and it works.
Old Jul 22, 2005 | 02:27 PM
dustin's Avatar
Interesting... hehe.
Well all I can suggest doing is getting a voltmeter. If is has power and ground, something should show up on the screen unless it is DOA.
Old Jul 22, 2005 | 03:38 PM
B6tPoweredMx3's Avatar
Actually i had a problem similar to this last summer. I had it installe din my car and the display just stopped working one day.
Go thru and make sure that all your connections are up to par.
no twisting and electrical tape allowed
Old Jul 22, 2005 | 07:07 PM
project dc2's Avatar
possible you pulled the connection inside the SAFC out. i did it once. i took it apart and reconnected it .
Old Jul 23, 2005 | 12:25 AM
RACEPAK's Avatar
Default Re: need help with my Safc. pro's only :p (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">possible you pulled the connection inside the SAFC out. i did it once. i took it apart and reconnected it . </TD></TR></TABLE>
thats it....
the1337aaron
14
Oct 12, 2010 06:16 AM
4gen5thtime
Apr 22, 2009 02:25 PM
4thgenHB157
Feb 17, 2005 05:23 PM
madlion
Sep 19, 2004 09:15 AM
00b18b
Jun 25, 2003 03:42 AM
