h22a swap .. several questions (pics)
Old Jul 21, 2005 | 03:14 PM
rcoolb2002's Avatar
Default h22a swap .. several questions (pics)
First off i appologize for the size of the first pic.. just wanted it to be large enough to see what i am questioning.
Second, i did do a little bit of searching, but due to my time schedule, and lack of patience, I decided to just post my questions and hope someone will answer me nicely.
A little bit of background info. I'm swapping an obd1 h22a into a obd2 chassis. Old motor was blown and disassembled in the car by someone else, so i really didnt have that much to go on as to placement of things in stock locations.
Questions part 1:
A: IAB (i believe) vacuum source. There was no vacuum line on the old intake manifold so im not sure where to source this vacuum.
B: correllates in some way with 'C' im pretty sure.. the question being, does it matter which vacuum line goes to which hard line?
C: see 'B'
Question 2: The following ground, does it have a specific location? It already appears to be grounded to the chasis... so does it go to the block somewhere?
Question 3: OBD1 motor sourced from HMO has the coil onboard the disty. Where does this external coil mount?
Thanks in advance for any help forthcoming.
~aaron
Old Jul 21, 2005 | 03:37 PM
94svtec's Avatar
Default Re: h22a swap .. several questions (rcoolb2002)
for question 2 the ground on my Lude goes to that driver side motor mount.. be sure to sand down to bare metal before you connect the ground wire. Good luck
Old Jul 22, 2005 | 05:32 AM
flyrod's Avatar
Default Re: h22a swap .. several questions (94svtec)
Q1A: The IAB is activated by a vacuum canister that mounts on the bottom side of the intake manifold, which in turn is charged through a one way valve and a line to the manifold.
Q1B: No, but one line is slightly bigger I think, so one hose may also be bigger.
Q2: It goes to the engine side of the motor mount. That mount is different than most OBD1 mounts I've seen, so there may not be a place for it. Just pick one of the 10mm bolts and use that maybe.
Q3: It mounts to the thermostat housing and the top of the outer most intake cam cap (where it looks like someone added a lift hook). It looks like part of the bracket is missing though. It's not really important how you mount it, but it normally looks like this:
Old Jul 22, 2005 | 12:45 PM
Sabbotage's Avatar
Default Re: h22a swap .. several questions (flyrod)
Maybe this diagram will help you too. This is what i used when i did my swap and i had no problems at all
Old Jul 22, 2005 | 03:52 PM
Fly1865's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">That mount is different than most OBD1 mounts I've seen, so there may not be a place for it.
The mount is different cause its the 5th gen driver mount.
Old Jul 22, 2005 | 07:20 PM
Slavko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
~aaron</TD></TR></TABLE>
If you have a distributor with an internal coil then you don't need the external coil at all. Just take it out I did the same thing on my h22 motor.
Old Jul 23, 2005 | 05:51 AM
rcoolb2002's Avatar
Default Re: h22a swap .. several questions (Slavko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slavko &raquo;</TD></TR><TR><TD CLASS="quote">If you have a distributor with an internal coil then you don't need the external coil at all. Just take it out I did the same thing on my h22 motor.</TD></TR></TABLE>
The plugs are different as im still using the obd2 wiring harness. I basically have to use the external coil.
Thanks for all the other information and the diagram sabbatoge
Old Jul 23, 2005 | 06:16 AM
Slavko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcoolb2002 &raquo;</TD></TR><TR><TD CLASS="quote">
Then you need to get an obd-2 distributor.
Old Jul 23, 2005 | 06:54 AM
Keith's Avatar
I wouldn't use an OBD1 dizzy anyhow. I used my 5th gen dizzy, IM, alternator, and oil pump. Makes things ALOT easier. There is no advantage to using those items from the JDM motor. I used the JDM motor + injectors... that's about it.
Keith
Old Jul 23, 2005 | 09:00 AM
rcoolb2002's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slavko &raquo;</TD></TR><TR><TD CLASS="quote">Then you need to get an obd-2 distributor.</TD></TR></TABLE>
I have one. The external coil disty. He was asking why i didnt just use the disty with the internal coil, and i was explaining why.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't use an OBD1 dizzy anyhow. I used my 5th gen dizzy, IM, alternator, and oil pump. Makes things ALOT easier. There is no advantage to using those items from the JDM motor. I used the JDM motor + injectors... that's about it.
Keith</TD></TR></TABLE>
Yeah i basically just used the longblock. I swapped injectors though, because of the plug difference. Simpler that way. I'm not getting payed very much to do this swap so im not overly concerned about things being PERFECT. Just as close to stock as possible.
kholmes
Feb 16, 2005 10:22 AM
slim9300
Apr 20, 2004 04:25 PM
