My itr wont start :(
The other night my itr made a weird sound when i start her, 2-3 starts later car wont start anymore
, my girlfriend had to push the car to start the engine then come back at home. I remove the starter and test it, and found it was ok, after that i found that the ring gear was loose
Is anyone here ever had the same problem ?? Yesterday i drop the tranny with a friend to change the flywheel and clutch (80 k mile on stock one). Ring gear was loose on the flywheel and the stock clutch disk was cracked, so i order some act goodies
, act prolite FW and act street disk is coming tomorrow. Ive also order a clutch bearing, pilot bearing and had my stock pressure plate resurfaced. Just want to be sure that i dont forget any pieces that i should replace before putting back the tranny in the car.
P-DuBB
May 29, 2006 03:14 PM
2K Teggy
Nov 30, 2004 10:18 AM
