Suspension & Brakes Theory, alignment, spring rates....
Advice on rear camber kit
Old Jul 21, 2005 | 02:01 PM
jromulo's Avatar
Default Advice on rear camber kit
I'm in need of a rear camber kit right now, which one do u guys advice me on getting? the car is just a daily driver, i don't need n e thing thats really expensive. lemme know wat you guys think...
thanks,
-jeffrey-
Old Jul 21, 2005 | 02:04 PM
Tyson's Avatar
Default Re: Advice on rear camber kit (jromulo)
if you just want to add some positive camber, then you can just shim the bolts at the upper control arm.
if you really wanted full adjustability, SPC has rear upper control arms.
i dont see why you really need to adjust the rear camber tho...
Old Jul 21, 2005 | 07:30 PM
Finger Lickin' good's Avatar
Default Re: Advice on rear camber kit (Tyson)
you can make do with some washers. I suggest just getting some washers. like 1/8 inch worth, put them on the inside of the two screws you see below. Will be enough for 1.5 inch drop.
Old Jul 30, 2005 | 09:27 AM
nocturnal EG's Avatar
Default Re: Advice on rear camber kit (D-CeReaL#4)
how many washers do you need and put them between what screws ??...and will this work if your rear tires are ALMOST tucked?...
Aftermath_Hatch
51
Dec 17, 2009 08:27 AM
kaluwa3
12
May 18, 2007 11:21 PM
dixie Normas7
Sep 8, 2006 11:17 AM
jeison
Jun 9, 2006 12:16 PM
Denny
Dec 15, 2002 07:22 PM
