FS: Ross Pistons 84mm Bore 8.5:1
Old Jul 21, 2005 | 01:53 PM
hondategra's Avatar
Default FS: Ross Pistons 84mm Bore 8.5:1
These pistons are brand spanking new. They have been sitting around so they have to go. They are 84 mm bore and are 8.5:1 compression. These are the prefect pistons for a turbo setup.
Factory description:
HONDA TURBO CHARGED B18-A1-B1, B18C, B16 COMPLETE KITS INCLUDING CHROMOLY RINGS AND PINS
All Honda kits include special heavy-duty pistons, which are designed and manufactured to perform flawlessly under the extreme heat and PRESSURE associated with turbo charged engines. Ideal for both street and serious competition, these pistons are loaded with extra features such as annular pin hole groves with double forced oil holes to prevent pin hole galling, and taper land to prevent scuffing. Extra thick lands for superior ring grove support under extreme pressure are made possible by intersecting the ring groove with the pin hole and using Ross Oil Ring Support Rails. 4340 taper bore, hard-chromed extra heavy-duty pins, along with Chromoly Rings are also included.
More Info @ http://www.RossPistons.com
$ 430 Shipped in the Continental US
PLease PM me or Reply with an email i can contact you .
Old Jul 21, 2005 | 02:00 PM
hondategra's Avatar
Bump
trickeng
Jul 30, 2008 04:41 PM
smoovy
Aug 29, 2005 04:28 PM
94mugenintegra
Mar 25, 2004 02:48 PM
94mugenintegra
Mar 22, 2004 08:36 AM
ReVtecSi
Apr 11, 2003 09:50 PM
