OBD1 Conversion Problems - CEL activation
Old Jul 21, 2005 | 01:20 PM
Modern91Hatch's Avatar
Default OBD1 Conversion Problems - CEL activation
I've put a B16a SIR2 in my 91 Hatch and I've got a wire conversion for the ECU. The conversion harness does not provide jumping for the Service Check Connector. What pins on the OBD1 ECU do I need to jump to get my CEL to display my error codes?
Normally, you would use the little jumper under the dash, but mines converted, so I need to know what to jump out of the ECU. Thanks
Old Jul 21, 2005 | 03:55 PM
Magick211's Avatar
Default Re: OBD1 Conversion Problems - CEL activation (Modern91Hatch)
What conversion harness did you use? They usally come with two wires tat arent used and you can twist them together
Old Jul 22, 2005 | 02:51 PM
Default Re: OBD1 Conversion Problems - CEL activation (Magick211)
I got a generic conversion without instuctions, so I need to know what Pins on the ECU I need to jump. I know about the Service Check Connector. I just didn't want start sticking in everything or applying voltage to it, ECUs arn't cheap to replace
Old Jul 22, 2005 | 04:11 PM
Mr_CRX's Avatar
Ground pin D4 to check the codes.
Old Jul 27, 2005 | 12:44 PM
Default Re: OBD1 Conversion Problems - CEL activation (Mr_CRX)
Thanks for the Info! I'll check it when I get my engine back in.
shaggyeg6si
Jun 28, 2008 08:30 PM
rasta420
Apr 6, 2007 08:12 AM
1gEF-8
Aug 10, 2005 01:54 AM
turboZChatch
Sep 30, 2004 01:30 PM
