mid range power loss skunk2 stage 2....
Old Jul 21, 2005 | 12:24 PM
lopaka07's Avatar
Default mid range power loss skunk2 stage 2....
Through my searches I found that people say skunk2 stage 2 cams loose mid range power and gain a bunch of top end but my question is, does it really loose mid range or just doesn't gain mid range power?
I've tried to search for dynos but couldn't find anything for a basic set up: example
b18c
i/h/e
skunk2 stage 2 cams
stock compression (higher is better of course)
Thanks
Old Jul 21, 2005 | 12:34 PM
EFvtec Yo!'s Avatar
Default Re: mid range power loss skunk2 stage 2.... (lopaka07)
man, i noticed the same thing with the skunk stg 1's in my old setup. I had a b16, aebs mannifold and the skunk stg 1's. It murdered my bottom end but it really picked up my top end. It might have helped if i had tuned them also.
Old Jul 21, 2005 | 12:36 PM
philafelman's Avatar
Default Re: mid range power loss skunk2 stage 2.... (EFvtec Yo!)
yeah, i just did a baseline run with my stage 2's zeroed out and compared my graph with my friends mildly built and tuned ls/vtec....his *** owned my midrange by a lot-but i did have more top end...however, probably could have done a lot better tuned.
Old Jul 21, 2005 | 01:35 PM
PURPLETERROR aka BIGMATT's Avatar
Tuning is key when switching to a performance cam. Almost all power losses can be fixed with proper tuning.
Old Jul 21, 2005 | 01:46 PM
Hybrid96EK's Avatar
Default Re: mid range power loss skunk2 stage 2.... (PURPLETERROR)
If you try to run those cams on stock compression levels then its going to cause a loss. Thats just all there is to it. The dynamic compression WILL be too low.
Old Jul 21, 2005 | 10:45 PM
lopaka07's Avatar
It seems to be that compression and tuning are the main issues with the skunk2 II's. Thanks for the info
Old Jul 21, 2005 | 11:37 PM
Takumi Fujiwara's Avatar
Default Re: (lopaka07)
With any performance cams, tuning should be a given.
Old Jul 22, 2005 | 12:55 AM
civicracer360's Avatar
toda B's for mid range power
Old Jul 22, 2005 | 03:48 AM
Chillinit's Avatar
Default Re: mid range power loss skunk2 stage 2.... (yosolo)
junk 2 and midrange don't belong in the same sentence. You will lose midrange with those cams. Its always been the case. I don't think I have seen anyone that gain any power/torque in the midrange section of the graph using skunk 2 cams or intake manifold. If someone has a graph that shows this, please post it!
Old Jul 22, 2005 | 05:12 AM
D-Rob's Avatar
Default Re: mid range power loss skunk2 stage 2.... (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">junk 2 and midrange don't belong in the same sentence. You will lose midrange with those cams. Its always been the case. I don't think I have seen anyone that gain any power/torque in the midrange section of the graph using skunk 2 cams or intake manifold. If someone has a graph that shows this, please post it!</TD></TR></TABLE>
Kind of a narrow-minded statement, don't you think?
What about the Pro 1+ cams? I'm pretty sure they make killer midrange.
Old Jul 22, 2005 | 07:00 AM
Chillinit's Avatar
Default Re: mid range power loss skunk2 stage 2.... (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">
What about the Pro 1+ cams? I'm pretty sure they make killer midrange.</TD></TR></TABLE>
Not narrow minded considering the Pro 1's are a brand new cam and their design intent on these cams differ from their previous selection. It took another company other then skunk 2, to put forth that power is not always determined by the amount of lift a cam has. *cough cough*...dur-a-tion?
I'm currently running BC3+'s and I have to say, I love the midrange on these babies. If you want a great street cam which will give you a nice midrange, you should consider running BC3+'s.
Old Jul 22, 2005 | 09:26 AM
oni3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">Tuning is key when switching to a performance cam. Almost all power losses can be fixed with proper tuning.</TD></TR></TABLE>
Yes!
Also, the Skunk2 stage2 cams require a higher compression, atleast 11:1.
Old Jul 22, 2005 | 04:39 PM
DonF's Avatar
Chillinit, Having dynoed the BC3+, BC4's Pro1's, M22x, and m24XX I would say you are wrong. When you dyno all of them get back to me.
Old Jul 22, 2005 | 05:38 PM
EHondaD6's Avatar
her you go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">Dyno'd his car a couple weeks back at Church automotive and the results where pleasant to say the least. heres the setup...
Long Block:
'00 SI B16A2
CTR PCT pistoins w/ honda rings std. bore (81mm)
ARP rod Bolts
ARP head studs
OEM head gasket, used 1 piece
Comptech Machine Street port w/ full radius valve job
ITR intake Valves
Portflow springs and retainers
Skunk Stage 2 cams and gears
ITR Intake manifold ported by Comptech Machine
ITR throttle body
MemoryFab J's style CarbonFiber Intake
Toda header
STr fuel rail
RC 310cc Injectors
CTR N-1 crank Pulley
Transmission
'00 SI
Kazz LSD
CTR flywheel
ACT Xtreme pressure plate
Clutch Net 6 puck sprung disc
all tuned with a Hondata Stage 3
Old Jul 22, 2005 | 10:41 PM
Y2K Si FBP's Avatar
i dyno'd 197 whp and 131 whtq....stage 2's are a decent midrange excellent high end cam...nice balanced cam.
with a flat flat torque curve.
stock 10.6 compression. i/h/e. mugen headgaskest..stock headcasting. stock block. kenji/vafc.
anyone want the dyno PM me.
Modified by Y2K Si FBP at 6:03 PM 7/23/2005
Old Jul 22, 2005 | 10:49 PM
UncleD's Avatar
Default Re: mid range power loss skunk2 stage 2.... (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">If you try to run those cams on stock compression levels then its going to cause a loss. Thats just all there is to it. The dynamic compression WILL be too low.</TD></TR></TABLE>
Agreed. 10.8 is NOT enough to run these cams, come on man..............you didn't expect to really gain mid range power did you??
*EDIT* I'm gonna assume that you're running the stock gsr ecu...how can expect vtec to engage with that low of compression at 4,500 on a vtec lobe that is enormous and NOT lose mid range!?
Old Jul 22, 2005 | 11:00 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lopaka07 &raquo;</TD></TR><TR><TD CLASS="quote">Through my searches I found that people say skunk2 stage 2 cams loose mid range power and gain a bunch of top end but my question is, does it really loose mid range or just doesn't gain mid range power?
b18c
i/h/e
skunk2 stage 2 cams
Thanks</TD></TR></TABLE>
Where is your vtec engagement point at ?
Set it atleast at 5600-5800 rpms....
Old Jul 23, 2005 | 12:33 AM
Hybrid96EK's Avatar
Default Re: mid range power loss skunk2 stage 2.... (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">
*EDIT* I'm gonna assume that you're running the stock gsr ecu...how can expect vtec to engage with that low of compression at 4,500 on a vtec lobe that is enormous and NOT lose mid range!?</TD></TR></TABLE>
He said B18C with stock compression. Last I checked that would be 10.6:1 at the highest assuming he is reffering to the JDM engine. Again, I don't feel this is high enough for a cam with that much durration, but hey, what do I know?
Silvertc
Apr 18, 2008 05:41 AM
civicsi0721
Jul 18, 2006 10:17 AM
JDM2ndGen
Aug 15, 2003 03:59 PM
warwagon
Feb 19, 2003 09:39 PM
