how the heck to i fix this? pictures inside.
bought a mount from jdmshit.com hpc auto to manual conversion transmission passenger side mount. here's some pictures below: i cannot bolt on 1 (red circle) of the nuts because there isn't enough clearance. any suggestions. that's a 92-95 ex/si transmission by the way.
update: jdmshit told me to use a set of visegrips to pull out that bolt and put in a longer 1?
that's what i'm saying... he said use "visegrips" i don't want to alter the transmission in anyway though. if i end up jacking up the thread on the screw by pulling it out, what then...
yeah
when u use 2 nuts.. it locks the nuts together.. then put some vice grips on the nuts and give it a good twist... ur gonna have to take the moutn back off obviously to get the bolt out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">Take two 17mm nuts and thread them together and then just turn it out.</TD></TR></TABLE>
good idea...
now how would i actually put in another bolt. they all have heads on them so it wouldn't even fit. i'm pretty sure that thing is welded inside, not hung on by a nut. i need some more input upon the transmission before i start tearing **** apart.
good idea...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">Take it out how I said and throw a same sized but longer bolt in the hole.</TD></TR></TABLE>
so not welded? there is an actual nut in there holding this bolt in place? and where do i find a bolt without a head?
some trans mounts come with a bolt there already. You are gonna discard the bolt thats in there now and get a regular bolt thats as long as you need and thread it in the hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">use a bolt with a head.</TD></TR></TABLE>
i can get it out now... but i'm lost again... won't the head of the bolt be larger than that of the actual threads causing it not to fit?
I believe those bolts are 17's might be a 19 not sure, just go into your box of spare nuts and bolts and find one that works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">
i can get it out now... but i'm lost again... won't the head of the bolt be larger than that of the actual threads causing it not to fit?</TD></TR></TABLE>
You lost me on that statement.
i got what you're saying now... we're going to screw in a bolt (not a nut) this time around to hold it in place. thanks dude... i appreciate your help <3. you just save me 80 from a hasport 1 and alot of trial and error time.
in ur first pic you have three holes on the mount, two have studs coming thru, the other one was meant for a bolt......got me?
Now find another bolt just like the one that goes into the other hole......got me?
Now thread that ****** into the hole, put the nut onto the other stud, and put the other stud into the hole. bam your done!!!! got it????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">i got what you're saying now... we're going to screw in a bolt (not a nut) this time around to hold it in place. thanks dude... i appreciate your help <3. you just save me 80 from a hasport 1 and alot of trial and error time.</TD></TR></TABLE>
oh yea, you cant screw a nut into a hole
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">in ur first pic you have three holes on the mount, two have studs coming thru, the other one was meant for a bolt......got me?
yes sir... it all makes sense now.. i always do things in reverse that's why. that never crossed my mind until i actually thought about it. well, i hope this post helps out lots of folks because that is the only way this mount works.
</TD></TR></TABLE>yes sir... it all makes sense now.. i always do things in reverse that's why. that never crossed my mind until i actually thought about it. well, i hope this post helps out lots of folks because that is the only way this mount works.
i meant use a nut instead of a bolt. it just didn't compute to my fingers like how it should've... give me a break. i hate you.
</TD></TR></TABLE>i meant use a nut instead of a bolt. it just didn't compute to my fingers like how it should've... give me a break. i hate you.
i meant use a nut instead of a bolt. it just didn't compute to my fingers like how it should've... give me a break. i hate you.</TD></TR></TABLE>
lol
lol
