AEBS Typhoon IM vs B16A1 IM dimensions (firewall clearance)
Old Jul 21, 2005 | 10:57 AM
alexdog69's Avatar
Default AEBS Typhoon IM vs B16A1 IM dimensions (firewall clearance)
is the AEBS manifold shorter than the B16A manifold?
i.e. does it reduce or increase firewall clearance?
Old Jul 21, 2005 | 11:56 AM
Modified Motors's Avatar
Default Re: AEBS Typhoon IM vs B16A1 IM dimensions (alexdog69)
no it reduces the firewall clearance. But it fit with my hasport mounts.
Old Jul 21, 2005 | 02:26 PM
FlatlineEF9's Avatar
Default Re: AEBS Typhoon IM vs B16A1 IM dimensions (Modified Motors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Modified Motors &raquo;</TD></TR><TR><TD CLASS="quote">no it reduces the firewall clearance. But it fit with my hasport mounts.</TD></TR></TABLE>
Yup, reduces clearance. But will fit. Do a search on the manifold to find out the other problems associated. I.E. fuel rail, gasket, etc.
Old Jul 21, 2005 | 02:36 PM
Ch3mik's Avatar
Default Re: AEBS Typhoon IM vs B16A1 IM dimensions (FlatlineEF9)
will fit. shorter runners. you will need to run an aftermarket fuel rail to fit your throttle cable bracket
Old Jul 21, 2005 | 02:38 PM
rioninja's Avatar
Fit with my HCP mounts.
Everything from my 2nd gen B16 swapped over. As stated, those with 1st gens are not so lucky..
Old Jul 21, 2005 | 02:49 PM
Autoworks's Avatar
Default Re: AEBS Typhoon IM vs B16A1 IM dimensions (rioninja)
What you need to put it on a 1st gen is a new fuel rail, to clear the iat sensor. Also shave the bottom of the mani a little above the alternator, because it will hit in that spot when you try to mount it.
Old Jul 21, 2005 | 03:51 PM
Crx Jimmy's Avatar
Default Re: AEBS Typhoon IM vs B16A1 IM dimensions (Autoworks)
mine didnt hit, i used a stock 99si rail -got it on ebay for 10bucks shipped
Old Jul 21, 2005 | 03:52 PM
Default Re: AEBS Typhoon IM vs B16A1 IM dimensions (Crx Jimmy)
I didn't have to shave mine either.
Old Jul 22, 2005 | 03:48 AM
Autoworks's Avatar
Mine did, I made a topic back in Jan. when I was putting my motor together, several peeps with 1st gens had the hitting problem, and only on 1st gens. It may have just been the mold of that particular batch. Can't really explain why, but about 1/8" had to be shaved off for it to sit fluch to the head due to it hitting the alternator bracket. Or I could have just shaved the alternator bracket down as well.
Old Jul 22, 2005 | 04:24 AM
Keith P's Avatar
Yup, a new fuel rail for 1st gen guys
I'm going to try to shave the silly fins off of the top of the manifold.. Silky smooth.
Old Jul 22, 2005 | 08:34 AM
alexdog69's Avatar
Default Re: AEBS Typhoon IM vs B16A1 IM dimensions (Keith P)
so there seems to be some conflicting reports here....
is the AEBS going to increase or reduce firewall clearance, when compared to a B16A1 intake manifold? anyone have pics of them side by side?
the B18C5 & skunk2 IM are shorter in overall length than the B16A1 IM, right? but the AEBS .... ?
as for the fins.. it would seem that the AEBS designer perhaps took his cues from vintage rat-rod/muscle parts (i.e. offenhauser) :-)
Old Jul 22, 2005 | 09:17 AM
Keith P's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexdog69 &raquo;</TD></TR><TR><TD CLASS="quote">
as for the fins.. it would seem that the AEBS designer perhaps took his cues from vintage rat-rod/muscle parts (i.e. offenhauser) :-)</TD></TR></TABLE>
Your probably correct. It just doesn't fit the styling of Honda.
I'll take a pic of the fire wall clearance when I get home tonight for you (with a measurement)
Old Jul 22, 2005 | 04:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexdog69 &raquo;</TD></TR><TR><TD CLASS="quote">so there seems to be some conflicting reports here....
Its designed by aebs and some meat-head company that makes manifolds and valve covers for mustangs and other tanks of that genre
Old Jul 23, 2005 | 09:08 PM
Ch3mik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">mine didnt hit, i used a stock 99si rail -got it on ebay for 10bucks shipped </TD></TR></TABLE>
i shoulda thought of that. oh well. lol
4g4db16
Jun 30, 2007 07:23 AM
turborex
Sep 1, 2003 05:01 PM
