Washer Fluid Squirters Not Working!
Old Jul 21, 2005 | 09:21 AM
HanSnobbler's Avatar
Default Washer Fluid Squirters Not Working!
Hi I've got a 90 honda accord sedan that doesnt have any problems besides the fact that when i try to use my wipers/washer fluid, no fluid comes out.
The wipers work, and there is fluid in the washer fluid resivior. No leaks, because i dont have to fill it and the sponge is still floating. The things on my hood that the fluid squirts from arent't clogged either.
Any suggestions or ideas would be greatly appreciated! Thanks ahead of time!
Old Jul 21, 2005 | 09:59 AM
CD7power's Avatar
Default Re: Washer Fluid Squirters Not Working! (HanSnobbler)
look under the hood and make sure that theres no lines kinked of clogged
Old Jul 21, 2005 | 01:09 PM
philadd's Avatar
Can you hear the washer fluid pump working? If you can't, check your fuses and/or pump.
If you can hear it, try pulling the hose off one of the nozzles and see if you can squirt water from the hose. (to make sure the nozzles aren't clogged)
Old Jul 22, 2005 | 06:20 PM
Default Re: Washer Fluid Squirters Not Working! (philadd)
im going to try that on monday...ill let you know how it comes out. thanks!
Old Jul 22, 2005 | 08:14 PM
sumptimwong's Avatar
i have the exact same problem in my volvo. i tried unplugging the hose right before the nozzle, and still no fluid. my next step would be to unplug different parts of the hose, working your back backwards, until you get some juice. if you finally work all the way back to the reservoir/pump, then i'd guess the pump has gone bad?
Melissa0901
Honda CR-V & Element
Apr 25, 2016 06:59 AM
Raguillon
Nov 12, 2013 02:06 PM
adrw1
Apr 18, 2007 11:17 PM
redDAinteg
Jan 4, 2007 01:53 PM
Thunder Cat
Dec 9, 2005 03:39 AM
