Integra LS brakes on 89 crx
Old Jul 21, 2005 | 09:03 AM
Wolfe55's Avatar
Default Integra LS brakes on 89 crx
I can get a 92 integra LS shell with full brakes on the car i was wondering if the integra brakes would fit my 89 CRX i would also doing a drum to rotor in the rear
would i need to buy anything to do the brake swap?
any advice ????
Old Jul 21, 2005 | 09:13 AM
Bunger's Avatar
Default Re: Integra LS brakes on 89 crx (Wolfe55)
Get the rears off the Integra, but get fronts off of a CRX VTEC (JDM or EDM), the DA knuckles are different and will change your suspension geometery. Besides that, get a bunch of brake fluid and bleed the system completely, also consider a larger master cylinder.
Old Jul 21, 2005 | 09:58 AM
CRX Toad's Avatar
Default Re: Integra LS brakes on 89 crx (Bunger)
Get the entire braking system out of the car, booster, MC, kuckles, and trailing arms.
You can use all this on your CRX but know that the DA will mess with your camber if you are not lowered. If you are lowered that DA knuckles will actually help to correct your camber. It will all swap over to your CRX. If it is an ABS car you can still use the booster and mc you will just need to change a fitting on the hard line, very simple just make sure you take that fitting off the line on the DA.
Old Jul 21, 2005 | 10:33 AM
BiG Chris's Avatar
yea i would do it if have the same opportunity im actually going to do it. all the breakes will bolt right on
Old Jul 21, 2005 | 12:59 PM
Wolfe55's Avatar
Default Re: Integra LS brakes on 89 crx (CRX Toad)
Thanks for the info glad to know it will correct my camber and that i can use the brake the integra also has a good trans i found out and a motor that smokes alot so maybe a b18b swap into the crx after fixing the b18b time will tell (and money)
thanks for the info
e1ght4vii
Mar 28, 2011 08:24 PM
road_romper
Mar 27, 2008 11:15 AM
gsrhatch530
Aug 16, 2005 12:35 PM
CRXTC
Jul 10, 2004 06:45 AM
12345
Oct 7, 2002 11:14 PM
