High Flow Catalytic Converter (Car sound)
Old Feb 18, 2002 | 07:32 AM
Nuts's Avatar
Default High Flow Catalytic Converter (Car sound)
Is the performance worth the $200 investment? Is the car will be a lot louder than the stock cat? I currently have Apexi N1 cat-back
Thanks,
CS
Old Feb 18, 2002 | 07:38 AM
Bob#455's Avatar
Default Re: High Flow Catalytic Converter (CS)
Yes, it is worth it. No, it is not a lot louder.
Old Feb 18, 2002 | 07:44 AM
Nuts's Avatar
Default Re: High Flow Catalytic Converter (Bob#497)
Thanks, does it help more on the top-end or lower end? or is it overall improvement?
CS
Old Feb 18, 2002 | 07:48 AM
Mike M's Avatar
Founding Member
Overall
Old Feb 18, 2002 | 07:49 AM
Bob#455's Avatar
Default Re: High Flow Catalytic Converter (TypeRmsm)
Overall
Less restriction = more power everywhere.
Old Feb 18, 2002 | 08:38 AM
1GreyTeg's Avatar
But, it would be alot better is you added a nice header to the mix!
Cat alone= a couple of HP maybe? Sound no biggy but, it does have a little more burble.
Cat and good header= potentially 10 or + HP depending on what you choose and the tuning you invest in.
As for me, I'm dynoing tomorrow, I'll post results for my intake, header/cat combo tomorrow evening. Good luck to me...
A.
Old Feb 18, 2002 | 08:45 AM
Nuts's Avatar
Default Re: High Flow Catalytic Converter (1GreyTeg)
thanks 1GreyTeg, I am still running the stock header now. If I get the carsound car now, do I have to get another cat in the future if I change the header later on?
Old Feb 18, 2002 | 08:47 AM
SMSP's Avatar
You can run a 2-1/4" with the stock set up. If you go with a JDM type or 2-1/2" collector header then you will need to upgrade but any USDM header that is strictly a bolt on item you'll still be able to use the 2-1/4" cat.
Old Feb 18, 2002 | 08:54 AM
1GreyTeg's Avatar
Depends if you are going to get a header with a 2.25" collector,"most mass produced USDM with exception," Or is you are going to go with a 2.5" collector, "most JDM and a few high quality USDM headers."
If you are doing mild stuff to your car then the 2.25 is OK but, if you plan on doing N/A worked stuff and /OR want the most out of you header and cat combo then the 2.5" is the way to go.
I am currently running a Spoon 4-2-1 and a Carsound 94006, I must say that the header seems to be quite a good mod for the R and when mated to the cat it's even better.
My vote for you is the same cat as I have, even if you don't have the header yet. Ask Mike "TypeRmsm" for fitment issues and correct parts #, He sells them.
Then after the Cat, you can investigate and take you rtime to save for the right header for you.
Good luck,
A.
Bob#455's Avatar
If you are going to spend money getting a high flow cat, then you shouldn't get anything smaller than 2.5". If you are going to get a 2.5" Carsound now, then you might as well upgrade the header too...
Old Feb 18, 2002 | 08:57 AM
1GreyTeg's Avatar
Oh yeah, Talk to SMSP about cats and headers.
He has cats for your needs and he manufactures one of the GOOD USDM headers with the 2 1/2 collectors of which I spoke.
A.
Old Feb 18, 2002 | 09:20 AM
Nuts's Avatar
thanks for all the help!! I need to do some research on the header now and see what's good...... jes.... this is getting more expensive!
anyway, thanks!
HottNikkels
Oct 16, 2008 04:18 PM
jered247
Honda Civic (2001 - 2005)
May 15, 2006 03:36 PM
LSintegra
Jan 10, 2006 06:08 PM
RegRedTeg
Oct 2, 2002 08:33 PM
TeamTooQuick
Apr 27, 2002 01:08 PM
