my Turbo ITR had lost all his oil
* 1st Video online now
VIDEO http://www.voehr.com/upload/store/ITRvsGT3.mpg
hi guys!
after 38000km, 25 hours on the race track and uncounted 1/4 mile starts I have the first bad defekt on my 400whp beast.
I feelt like Takuma Sato in the 2004ish Monte Carlo F1 gp when on the back of his car a huge amount of white smoke came out of the car. Too bad I have no rear camera, cause with my new HONDA sticker in the rear wing it would have become an awesome video. hehe ..........well, but it was filmed from the pits, I hope to get the film material very soon!
In the second turn of Brno Race way in Czech republik at 230kmh once of a sudden the red oil pressure signal burned my eyes!!!!! Within 2/10 of a second I shutted off the engine....that should help me from damaged bearings, etc. I HOPE SO! All of the good 10w60 engine oil (5 litres) flushed on the hot exhaust and became a white nice steam! All the people told me it looked very spectacular!
Well, that happend to my car: The hollow-bolt that came with the Graddy Sandwitchadapter which is screwed into the water/oil heat exchanger was the problem. 3 years ago we screwed this bolt directly into the block, cause I got rid of this heat exchanger. We did not know that the Greddy bolt has a few threads less than the oem Honda bolt. There is a little alu material coming out of the block where the threads are in for the hollow-bolt. This engineblock alu material BROKE off!!!! If there were only 2 or 3 threads more on the hollow bolt NOTHING had happend I guess.
My friend will produce me an longer hollow bolt now. After the install is finished I will fill up the engine with oil and reactivate that bitch. I hope not to hear any abnormal noises......
...but I have good feelings since I was able to shut off the engine immediatly!
Besides all of that I was able to kill some Porsches, Ferraris, new M3, etc.......
Modified by austrian type-R at 8:44 PM 7/28/2005
hi guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R »</TD></TR><TR><TD CLASS="quote">
Besides all of that I was able to kill some Porsches, Ferraris, new M3, etc....... </TD></TR></TABLE>
Ultimately...this is the most important thing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">Ultimately...this is the most important thing
And the most fun, might i add
</TD></TR></TABLE>And the most fun, might i add
Very sorry to hear what happened and that it happened in Brno - my town
. Were you going 230kph at the end of the finish line? In my stock R, I usually go 190kph to turn 1, about 180 in turn 3, then about 170-180 in turn 5 and 180 in turn 10. Then it's uphill, so #13 is only about 150:
Pity that I didn't know that you are racing here, I would come to see your R. What are your lap times? My best is 2:47
on road tires.
Hope there is no internal damage and everything will be OK
PS: for those who don't know this track, here are some pics and here is some video from the track.
on road tires.Hope there is no internal damage and everything will be OK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R »</TD></TR><TR><TD CLASS="quote">My best lap time was a 2:26. I can shift into 5th uphil, about 215kmh or so.</TD></TR></TABLE>
your R is a beast!
Are you running slicks? What is your top speed on that track? I assume >240?
your R is a beast!
I usual< do not look much to the speedo, but 240kmh is about what it has to be, since I shift in 5th and stay a few seconds in it. (I have a longer geared GSR tranny too)
I run Dunlop 200/580/15 Slicks in Volk te37 7x15inch which fits over my AP 4 piston caliper kit
Good luck with the motor.. you should be okay.. crossing my fingers.
Your car is mean as hell.. still got that video of you on thetrack hauling *** by the ferrari's? i lost it somehow.
Is that the Greddy sandwich adapter on the pic? It looks nearly identical to my Mocal unit (with a thermostat).
Modified by Pompiuses at 9:40 PM 7/21/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando »</TD></TR><TR><TD CLASS="quote">Where's Chris F? You guys are buddies now....</TD></TR></TABLE>
Hahaha!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">I will fill up the engine with oil and reactivate that bitch
Yeah, sounds like that's my new sig too! Sweet!
Damnit, I have that GReddy sandwich adapter too. At least I have the stock heat exchanger. I need a bigger oil cooler though, my oil temps still SUCK (310+, hard to say, off the end of the scale on the temp gauge)
Hahaha!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor »</TD></TR><TR><TD CLASS="quote">Ehh..oils just a small thing! I like the important part, beating ferrari's and porsches </TD></TR></TABLE>
If you have a big enough oil slick, you can take out Vipers too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">I will fill up the engine with oil and reactivate that bitch </TD></TR></TABLE>
Maybe make up a couple more of those hollow fittings (the bolt/tube you spoke of) is there's much interest from the rest of us.
Please let us know how it turns out.
WOW! A big brake kit that works with 15's. Bet that's worth a pretty penny......
</TD></TR></TABLE>WOW! A big brake kit that works with 15's. Bet that's worth a pretty penny......
I bet it's one of these : http://www.apracing.com/car/brakekit/index.htm
The Integra kit uses a 295x28mm rotor and a 4 piston caliper, and yes it is claimed to be fitting under 7x15" wheels. Available either with a bolted or a floating disc.
Not cheap, but very nice.
Pretty similar to what happened to me. Was merging into the freeway; redlined 3rd gear and my freakin oil filter popped off. I thought it blew for sure. I have a greddy/trust oil cooler on my car, it might have been my fault for not tightening it enough but I'm a little weary about that sandwich adapter.
I just checked the shaft-play on the Turbo today. There is no play
I get my new hollow bolt this week
It seems this hollow bolt has gotten loose and when it only held 4 threads into the block, the aluminium of the block broke off. Well, I get an new 9mm longer hollow bolt any way.
