D16a6 vs sohc zc for turbo
Old Jul 21, 2005 | 03:23 AM
DaMmniTz's Avatar
Default D16a6 vs sohc zc for turbo
goal: building a all motor sohc turbo.
Questions:
What's the weight difference between a D16a6 and a Sohc ZC complete motor?
Which one would you turbo? Not interested in Dohc motors. Only these two. Advice welcome.
1988 CRX HF D16A6 TURBO
180 whp / 175 ft. trq @ 7 psi
Friend's setup.
Old Jul 21, 2005 | 04:44 AM
purplecrx's Avatar
They're identical. SOHC ZC = JDM D16A6. Only difference is the camshaft, which is more aggressive, giving the ZC a 10hp advantage. Swapping a ZC cam into an A6 head would theoretically yield a SOHC ZC minus the branding. I've heard claims that the head flows better, but I believe that to be hearsay as I have both heads. Obviously I haven't flowbenched both or anything, but they look identical.
Old Jul 21, 2005 | 05:23 AM
DaMmniTz's Avatar
Default Re: D16a6 vs sohc zc for turbo (DaMmniTz)
thanks for the info. Now i can start my turbo setup.
Old Jul 21, 2005 | 07:11 AM
HumanResource's Avatar
also SOHC ZCs come with the 4-2-1 header vs. the 4-1 for our USDM D16A6.
Old Jul 21, 2005 | 08:21 AM
Mr_ET's Avatar
Default Re: D16a6 vs sohc zc for turbo (HumanResource)
indeed but my 4-2-1 does not bolt up to the stock cat on my 91 si
btw you can't have an all motor turbo man it's one or the other
Old Jul 21, 2005 | 10:01 AM
suspendedHatch's Avatar
Default Re: D16a6 vs sohc zc for turbo (Mr_ET)
Do the engines have the same compression?
Old Jul 21, 2005 | 10:18 AM
Skinflute22's Avatar
yes they should have the same compresion because the blocks are identical i believe
4runner's Avatar
[QUOTE=
Friend's setup. [/QUOTE]
trooper0641
i live near thsi guy!
Old Jul 21, 2005 | 10:29 AM
Tyson's Avatar
heres a comparison of ZC cams to A6. you should note that the carbed SOHC ZC cam is different than the MPFI ZC. also, the late model sohc ZC does have the compression ratio bumped up to 9.4 i believe.
i think its the combination of the 4-2-1 exhaust and higher intake cam of the JDM-D that provides the extra horsepower. my opinion is that the 4-1 exhaust manifold just sucks, and any aftermarket header is going to give you back that lost power on a US-D.
http://www.norcalcrx.org/tyson/SOHC_Cam.html
2nxcrx
86
Feb 1, 2012 05:41 AM
4genblack
May 31, 2004 07:25 AM
Dwight Schrute
Feb 22, 2004 03:01 PM
Serdar
Aug 13, 2003 04:43 AM
hondacivic4g
Aug 22, 2002 05:26 AM
