Ran out of gas? Added fuel and it wants to turn over but doesnt?
Old Jul 21, 2005 | 01:36 AM
trooper0641's Avatar
Default Ran out of gas? Added fuel and it wants to turn over but doesnt?
I was driving, my gauge hasnt been working recently because of stupid reasons. Anywhos, I tried to play it safe by driving slowly...but I guessed I ran out of gas and my car died. I went to get 3 gallons worth to put it into my tank but still no luck. It sounds like it wants to turn over but just doesnt stay on. Seems like theres isnt constant gas flow. Any ideas? I can still hear my fuel pump priming.
And also...now theres a loud vaccum sound coming from - underneath the intake manifold and in the middle. Sounds like my breather box. But could that cause my car to not start also?
Old Jul 21, 2005 | 01:48 AM
gaydm.accord's Avatar
you have kill switches in your car? fuel pump kill?
i know when this happened to me my fuel pump switch fried... then i hooked another one up with a relay and it solved my problem.
Old Jul 21, 2005 | 01:51 AM
one more thing...
you might have flooded your engine by trying to start it which is that vacuum noise your hearing.
Old Jul 21, 2005 | 06:20 AM
Newark Built's Avatar
* B A N N E D *
Default Re: (gaydm.accord)
Might also be your fuel filter...That happened to me once.
When you ran out of gas it might have sucked up all the dirt and ish on the bottom of your tank...Quick and easy to do, give it a try.
Old Jul 21, 2005 | 11:20 AM
Default Re: (Newark Built Kandy SiC-RX)
thanks for the info guys any more comments?
Old Jul 21, 2005 | 11:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">one more thing...
you might have flooded your engine by trying to start it which is that vacuum noise your hearing.</TD></TR></TABLE>
flooded with gas? it sounds like a loud *** vacuum, im not too sure what it is...but it sounds like the breather box ish.
Old Jul 21, 2005 | 11:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">you have kill switches in your car? fuel pump kill?
i know when this happened to me my fuel pump switch fried... then i hooked another one up with a relay and it solved my problem.</TD></TR></TABLE>
no i dont have any kill switches or anything like that. thanks though
Old Jul 21, 2005 | 12:02 PM
CRX Toad's Avatar
Default Re: (trooper0641)
Have you tried putting any gas into the intake manifold, just a little bit or any starting fluid?
Old Jul 21, 2005 | 01:31 PM
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried putting any gas into the intake manifold, just a little bit or any starting fluid? </TD></TR></TABLE>
I havent tried it but...when I start my car, it seems like theres just enough gas for the car to crank and start on for like 3 secs and then dies. Like there is no consant gas flow but I can hear my fuel pump priming for sure.
Old Jul 21, 2005 | 01:49 PM
Steve91's Avatar
Default Re: Ran out of gas? Added fuel and it wants to turn over but doesnt? (trooper0641)
You probably killed your fuel pump. When you run out of gas, the fuel pump keeps going. The fuel pump needs gas to cool and lubricate it. Running it without gas will kill it in a minute or less. Its like running an engine without oil.
Old Jul 21, 2005 | 02:17 PM
Default Re: Ran out of gas? Added fuel and it wants to turn over but doesnt? (Steve91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve91 &raquo;</TD></TR><TR><TD CLASS="quote">You probably killed your fuel pump. When you run out of gas, the fuel pump keeps going. The fuel pump needs gas to cool and lubricate it. Running it without gas will kill it in a minute or less. Its like running an engine without oil.</TD></TR></TABLE>
Interesting, any comments on this?
Old Jul 21, 2005 | 02:20 PM
purplecrx's Avatar
Get a new fuel pump. Sounds like it is fried. Gas = Lubricant/Coolant.
Old Jul 21, 2005 | 08:17 PM
Default Re: (purplecrx)
bump this **** up
Old Jul 21, 2005 | 09:16 PM
help a brotha out
Old Jul 21, 2005 | 10:48 PM
pull your spark plug out and see if the plugs are wet.
you said it starts but then shuts off does it bog down??? try all the cheap stuff first befor eyou replace the expensive ****. weed out all the inexpensive and easy to do stuff.
and if you have any electrical components hooked up for management you might want to check your connections also.
Old Jul 21, 2005 | 11:29 PM
4runner's Avatar
sup chye lo
Old Jul 22, 2005 | 09:09 AM
Default Re: (88HaveFun)
twetert
Old Jul 22, 2005 | 09:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88HaveFun &raquo;</TD></TR><TR><TD CLASS="quote">sup chye lo </TD></TR></TABLE>
WHADDUP BITCHES!
Old Jul 22, 2005 | 10:56 PM
24wefgwgw
Old Jul 23, 2005 | 05:26 PM
yes!
Old Jul 23, 2005 | 08:31 PM
23r23r32r
Old Jul 24, 2005 | 01:45 AM
23rrwef
goldenmustache
38
May 13, 2009 07:04 PM
dreadhead89
Dec 26, 2008 09:14 PM
ken hill
Mar 27, 2008 07:10 PM
extreme90civic
Aug 29, 2005 06:45 PM
dunkd
Nov 17, 2004 05:57 PM
