Double-Clutching?
Old Jul 20, 2005 | 11:19 PM
AznMTboy's Avatar
Default Double-Clutching?
does any body how to do "Double-Clutching" or is there no such thing?
Old Jul 20, 2005 | 11:23 PM
Sack Master's Avatar
Default Re: Double-Clutching? (AznMTboy)
Yeah if you're a truck driver. That's awesome. Sorry I'm not gonna flame you but I'm not gonna answer that question. Good times
Old Jul 20, 2005 | 11:28 PM
rdblckSV650S's Avatar
i'ts not necessary on our cars because we have gear syncros. It's also used only during down shifting, it has nothing to do with the 1/4 mile or vin diesel.
Old Jul 20, 2005 | 11:31 PM
Senbonzakura's Avatar
Default Re: Double-Clutching? (slvrblckf4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrblckf4i &raquo;</TD></TR><TR><TD CLASS="quote">i'ts not necessary on our cars because we have gear syncros. It's also used only during down shifting, it has nothing to do with the 1/4 mile or vin diesel.</TD></TR></TABLE>
Hahaha Vin Diesel
Old Jul 21, 2005 | 12:25 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Re: Double-Clutching? (Kyo Kusanagi)
Vin says:
"Fine. Don't double clutch. But don't come cryin' to me when you fry your piston rings, blow your intake welds, and lose your floorpans, you granny shifting H-T-reading bitch!"
Old Jul 21, 2005 | 12:34 AM
rsintegra's Avatar
Default Re: Double-Clutching? (^^whatnoobsearchthenGTFO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^^whatnoobsearchthenGTFO &raquo;</TD></TR><TR><TD CLASS="quote">Vin says:
haha...nice reply!
Yeah, double clutchin in our tegs is worthless. "Granny" shiftin is the way to go.
Old Jul 21, 2005 | 12:41 AM
LSvtec03's Avatar
Default Re: Double-Clutching? (rsintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsintegra &raquo;</TD></TR><TR><TD CLASS="quote">haha...nice reply!
Yeah, double clutchin in our tegs is worthless. "Granny" shiftin is the way to go.</TD></TR></TABLE>
i wouldn't say worthless. synchros can wear out.
Old Jul 21, 2005 | 12:49 AM
APC4Life's Avatar
Default Re: Double-Clutching? (LSvtec03)
LOL that was soo funny!!! LOL .... Beacuase we all know that he saw "The Fast & the Furious" and why he wants to know how to double clutch.. Well since were on the subject of F&F here ya go!!!
IM in YA FAce!!!! Dont come around here again!!! You were just fired!!!
Modified by APC4Life at 5:40 AM 7/21/2005
Old Jul 21, 2005 | 12:51 AM
Contender25
Guest
Posts: n/a
This is not helping him. But on a side note don't bother you will fry you'r clutch.
Old Jul 21, 2005 | 02:18 AM
@.com's Avatar
Double clutching (useless)
Power shift (dont mess up). Got me into 15's.
Still slow but its all good.
Old Jul 21, 2005 | 02:44 AM
LSvtec03's Avatar
Default Re: Double-Clutching? (@.com)
double-clutching is useless, but you powershift?
Old Jul 21, 2005 | 05:27 AM
lVlemphizStylez's Avatar
how would double clutching hurt the clutch...lemme make sure i understand though...clutch in...neutral...blip to the appropriate rpm...slide in gear...release clutch...hows that excessive wear on it? unless im thinking of something else
cause when i downshift i do that to reduce the wear on the synchros...at the right rpm itll just suck into gear
Old Jul 21, 2005 | 05:36 AM
LSvtec03's Avatar
Default Re: Double-Clutching? (lVlemphizStylez)
it's - clutch in, shift to neutral, clutch out, blip throttle, clutch in, in gear, clutch out.
Old Jul 21, 2005 | 05:45 AM
ohhhhh i dont release the clutch in neutral...i just keep it disengaged...blip then slid into gear...
Old Jul 21, 2005 | 05:56 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">ohhhhh i dont release the clutch in neutral...i just keep it disengaged...blip then slid into gear...</TD></TR></TABLE>
what you're doing is called rev matching, and it's good for saving the synchros.
Old Jul 21, 2005 | 06:18 AM
Liquidgsr's Avatar
yeah my cousin just taught me how to do that so the my gears don't grind. If i don't then they grind at high RPMs. Worked for me and kept my trans from grinding when pushing it.
Old Jul 21, 2005 | 06:43 AM
TheBobFather's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">it's - clutch in, shift to neutral, clutch out, blip throttle, clutch in, in gear, clutch out.</TD></TR></TABLE>
Thats a whole lot of clutch going on...lol. Sounds like you will loose a couple seconds doing this
Old Jul 21, 2005 | 07:09 AM
2G0S0R1's Avatar
New User
CORRECT! Few people here do that correctly, as I learned from another thread... haha
Something I do sometimes, which I refer to as "double-clutching" even though it is different, Is to pop the clutch while giving it some full throttle. Lets say you are casually shifting... and while you are in the middle of second gear (about to shift to third) you decide you want to get your speed on. Without doing any shifting... you press the clutch while flooring it and then drop it back out a half second later. This will get you out of your midrange and into your upper rpm band (slipping a little clutch/tires) much faster than pushing through 4k...5k...~6k... rpms.
Kinda like this:
1st________2nd________(clutch in+throttle)***(clutch out)_________3rd_____....
- -(~3500rpm)^ - - - - (~3500rpm)^ - - - (&lt;6000rpm)^ - - (&lt;8500rpm)^
Been working for me for 3 years... clutches still last 50k+... helps you out when some clown is coming up on you for a pass or whatever and your just cruising, but you want them to think they are going to win before you really get the best of them. haha. Flame me if you want. Pfft...
Old Jul 21, 2005 | 07:16 AM
kevpotts's Avatar
Default Re: Double-Clutching? (2G0S0R1)
a friend of mine does that.im skeptical on whether it actually does anything other than just rev and launch... but i mean... we are already going 35. I would just down shift, or accept that im not gonna make the light
Old Jul 21, 2005 | 07:49 AM
User 42624's Avatar
Default Re: Double-Clutching? (kevpotts)
lol i wanna go watch slow and curious now ahah
Old Jul 21, 2005 | 08:35 AM
StickyGreen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznMTboy &raquo;</TD></TR><TR><TD CLASS="quote">does any body how to do "Double-Clutching" or is there no such thing?</TD></TR></TABLE>
it's a lame coneption that pushing down on the clutch while your at WOT will give you an extra push
Old Jul 21, 2005 | 08:44 AM
justin.parker's Avatar
I was taught that if you match revs correctly you don't use the clutch to get back into gear, as the gears are already perfectly in sync. If you slide it in gear it goes in smoothly and without any trouble at all. I thought this was how it was supposedly done. Granted, as all of you have said, its more or less completely useless and is just used as a fashion show.
Old Jul 21, 2005 | 08:45 AM
EJ1 wilcox's Avatar
Default Re: Double-Clutching? (KaSER)
I don't double clutch...
But I do full-throttle shift on the drag strip... Now that's some ****!
Old Jul 21, 2005 | 09:14 AM
TunerN00b's Avatar
Default Re: (justin.parker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justin.parker &raquo;</TD></TR><TR><TD CLASS="quote">I was taught that if you match revs correctly you don't use the clutch to get back into gear, as the gears are already perfectly in sync. If you slide it in gear it goes in smoothly and without any trouble at all. I thought this was how it was supposedly done. Granted, as all of you have said, its more or less completely useless and is just used as a fashion show.</TD></TR></TABLE>
If you time it right, you don't need the clutch at all, after you get moving.
Rev up in first, let off gas and pull sitck to neutral (one motion, you need to get the load off the gears), wait for revs to drop to exactly where they would be in the next gear, slide stick into next gear. Worked like a charm in my cavalier, works perfectly fine in my gsr, haven't tried in my spitfire (26 year old gears and all that). I wouldn't try it unless you are very comfortable with the transmission, you will place a lot of strain on the synchros if you mess it up.
Also, for double clutching, it helps with with 1 -&gt; 2 upshift in older VWs. From first, push clutch, drop into neutral, let out clutch, wait for revs to drop to appropriate speed, clutch in, shift to 2nd, clutch out. They frequently grind if you try and shift too fast, from my experience.
Old Jul 21, 2005 | 09:17 AM
LSvtec03's Avatar
i do that sometimes. keeps me entertained on boring drives.
btw, this does NOT work in celicas. ask me how i found out.
