Are the 88-91 Si and HF harness the same as obdo 90 integra?.
Old Jul 20, 2005 | 10:12 PM
Contender25
Guest
Posts: n/a
Default Are the 88-91 Si and HF harness the same as obdo 90 integra?.
Need to know if the OBDO acura integra i think was 90 and 91? b18a wiring harness is the same as the HF or SI wiring harness out of the 88-91 civic/crx. Like basically i need to know if you can use the stock harness with a b18a OBDO Ecu, on a b18b, btw it Does have a OBDO dizzy already.
Old Jul 20, 2005 | 10:23 PM
Malgerus's Avatar
Default Re: Are the 88-91 Si and HF harness the same as obdo 90 integra?. (Contender25)
Nope. I highly doubt it. Harnesses are hardly interchangable between 88-91's, don't see why they would be with a 1990-91 Integra harness.
Old Jul 20, 2005 | 10:30 PM
Contender25
Guest
Posts: n/a
They should be, or i would think interchangable, because the 90 and 91 integ i think was OBDO like the 88-91 civic/crx si and hf models.
Old Jul 20, 2005 | 10:31 PM
Contender25
Guest
Posts: n/a
I need to know in english if i can use a Si or HF wiring harness with a b18b with a OBDO b18a dizzy on it with b18a OBDO ecu.
Old Jul 20, 2005 | 10:38 PM
Contender25
Guest
Posts: n/a
Nvm
Modified by Contender25 at 1:49 AM 7/21/2005
Old Jul 20, 2005 | 10:39 PM
eda6's Avatar
Default Re: (Contender25)
I don't know what you're trying to accomplish...
The easiest thing you can do is modify your existing harness to run the b18. Use the Si/HF harnesses for parts.
Old Jul 20, 2005 | 10:43 PM
Contender25
Guest
Posts: n/a
I have a ******* crx hf with a 94 b18Bitch, the obd1 motor b18b and it has a obdOOOOOOOO 90/91 b18A distributor. So basically the harness should be the same, if not a couple plugs needing to be replaced or change out to fit, and the ecu of course being a obdO b18a ecu plugs up the same.
Old Jul 20, 2005 | 10:45 PM
Contender25
Guest
Posts: n/a
B18b obd1 motor+obdo b18A distributor+stock HF/SI wiring harness+b18a obdo ecu= ready to start right??. I guess some people are in the first grade.
classciv
Mar 5, 2007 05:45 PM
Contender25
Jul 20, 2005 11:09 PM
crxb18a1
24
Aug 14, 2004 05:39 PM
