MSD Ignition System
Old Jul 20, 2005 | 09:10 PM
Zatzy's Avatar
Default MSD Ignition System
Now I know the MSD makes a wide variety of ignition systems for the import 4cyl. I am running an LS/Vtec in my 89 CRX and I was wondering what would be the best MSD system to run with this....if there is anything you need to know to help further an answer just ask. I want to run the Blaster 2 coil so i need a new cap. or is it worth it?
Old Jul 21, 2005 | 01:17 AM
Bunger's Avatar
Default Re: MSD Ignition System (Zatzy)
Keep it factory, unless you're running a seriously crazy setup, you're not going to see any power difference.
Old Jul 21, 2005 | 07:19 AM
Zatzy's Avatar
Default Re: MSD Ignition System (Bunger)
Well I am running an all motor LS/Vtec motor that has a 9500 rpm redline and i know that the stock coil in the dizzy is pretty weak at high rpm
Old Jul 21, 2005 | 07:56 AM
CBURKE's Avatar
No, Honda has very strong ignition systems. They can hold at least 250hp. But if you mind is set on it, then just get the sports compact one. that would be fine.
Neesmo31
Jan 13, 2009 10:38 PM
hondaluver12
16
Dec 10, 2008 02:32 PM
NA90hatch
May 8, 2005 06:22 AM
out_of_order
Apr 18, 2004 08:26 PM
marques4130
May 10, 2003 12:16 AM
