Damaged rear spindle - replace?
So I was replacing the left rear wheel bearing on my 92 teg yesterday when I ran into a problem. The inner race of the old bearing was firmly stuck on the spindle, and I ended up having to cut it off with an angle grinder. Unfortunately, I also managed to cut slightly into the spindle
Now, I put the new bearing/hub on and put everything back together, and everything seems fine, but I'm thinking I should probably still replace the spindle. Should I replace it, and, if so, will a junkyard sell me just the spindle or will I have to buy a complete trailing arm? TIA
Cliffs: Accidentally cut into spindle, replace or no? Can I get it seperately?
Now, I put the new bearing/hub on and put everything back together, and everything seems fine, but I'm thinking I should probably still replace the spindle. Should I replace it, and, if so, will a junkyard sell me just the spindle or will I have to buy a complete trailing arm? TIACliffs: Accidentally cut into spindle, replace or no? Can I get it seperately?
mang i know those damn junk yard dudes will prolly sell u the whole trailing arm. if its doing good then drive on it for awhile and see wat sup.
i been driving on a bad hub bearing on my rear for awhile and still didnt replace it yet.
eg:R
10
Oct 15, 2011 02:15 PM
jasonb
Jun 22, 2002 07:17 AM
