Just installed 90-91 DA Integra lip onto my 90 4dr
I just got done putting my 91 Integra lip on my Civic. Turned out pretty clean if I say so myself.
The mounting points itself are dead on between the integra lip and the Civic bumper. By that I mean on the underside of the bumper, the holes for the lip to bolt on, line up exactly with the DA lip.
All you need from the DA is the lip, the mounting bolts, and the metal mounting clips that are attached to the DA's bumper (for the bolts to screw into). THe clips will fit perfect into the holes on the Civic bumper. Slip all the clips onto the Civic bumper, then bolt up the lip. On both sides, the lip needs to be cut about 1in - 1 1/2in. You'll see exactly how much you need to cut off when the lip is mounted. I used a SawZall to cut the extra length off.
After you cut off the excess plastic, on the lip there will be a tab that sticks out about an inch going in toward the car. Drill a hole there so that you can put the last bolt in and bolt the lip up snug into the bumper, and thats it!
Sorry for the crappy pics, the sun was going down, and the flash made it look weird...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef four door »</TD></TR><TR><TD CLASS="quote">Clean four door...im feelin the MR5s. Is that a panasonic phone on ur car?</TD></TR></TABLE>
Haha thanks man. Nah its a Uniden. I had a VTECH cordless one before but it was a piece of ****
dapdabbin
Nov 24, 2012 07:11 AM
