Fuse box help (pic)
Old Jul 20, 2005 | 06:43 PM
Cee_mon's Avatar
Default Fuse box help (pic)
On the C918 spot [Option (no. 19 fuse)]
Does that mean the number 19 fuse on the box will be the fuse for an option if you choose to use that spade connector C918?
Old Jul 20, 2005 | 07:00 PM
EE_Chris's Avatar
Default Re: Fuse box help (Cee_mon)
It seems that Fuse 19 provides battery voltage to a lot of lights when the headlight switch is turned on. So C918 only gets battery voltage in that condition - when the headlight switch is turned on for the headlights or the parking lights.
nocturnaldragon's Avatar
I dont belive those are fused but I could be wrong.
Old Jul 20, 2005 | 07:12 PM
Cee_mon's Avatar
Default Re: Fuse box help (EE_Chris)
But it is fused under the fuse 19 right?
Iam using this to wire up a wideband and i wanna have a fuse for it just incase. I thought this would be the best option.
Old Jul 20, 2005 | 07:18 PM
EE_Chris's Avatar
Yes, C918 is after Fuse 19. But if you choose to wire your wideband to it, it would only work if you had the parking or head lights on.
Old Jul 20, 2005 | 07:27 PM
moto1320's Avatar
There are other ones in the same row that you can grab power off that are hot key on. I always grab voltage there for gauges. if you want to fuse your wide band you can pick up a fuse holder and solder it into whatever you want. I use them all the time in line with jumper wires for testing.
dhealey
Honda CR-V & Element
11
Jun 5, 2024 06:31 PM
HondaTech101
Apr 7, 2007 06:59 AM
GreenD16Y8
Aug 8, 2005 03:59 PM
ModlesSI
Feb 22, 2003 03:16 PM
