Suspension & Brakes Theory, alignment, spring rates....
Neuspeed Springs Which is front and Rear.? Short front or long springs on front?
Old Jul 20, 2005 | 05:33 PM
SiB16A's Avatar
Default Neuspeed Springs Which is front and Rear.? Short front or long springs on front?
I installed Neuspeed Springs on my car. The back is lower then the front. are the shorter springs suppost to go on the front and the longer springs suppost to go on the rear? I DID look at the F & R on the springs and installed them right, but the car is way lower on back then front. I have about a 1 finger gap rear and 2 finger gap up front. Do you think neuspeed printed the F & R on the springs wrong? The car should be lowered 2 1/4 front and 2 rear. But its the totally opposite.
Old Jul 20, 2005 | 06:03 PM
ecahatch's Avatar
Senor Miembro
Default Re: Neuspeed Springs Which is front and Rear.? Short front or long springs on front? (SiB16a)
then maybe u installed em wrong...if you said u read F&R
Old Jul 20, 2005 | 07:22 PM
stumpyf4's Avatar
Length won't really help you. Look at the diameter of the spring wire and compare. Larger diameter wire should go on the front.
Old Jul 20, 2005 | 10:58 PM
SiB16A's Avatar
Default Re: Neuspeed Springs Which is front and Rear.? Short front or long springs on front? (stumpyf4)
they are already on my car is there another awy to check?
Old Jul 27, 2005 | 06:59 PM
Crazydave's Avatar
well if your car is sitting really really really low,
you probably have them on backwards.
AllmotorGSReg
Apr 23, 2009 05:57 AM
gofastgsr
Mar 23, 2004 09:50 AM
LSBlackInteg
Apr 11, 2003 06:21 PM
WangChung
Feb 13, 2003 02:16 AM
