upgraded valvetrain with stock cams
Old Jul 20, 2005 | 04:20 PM
white_n_slow's Avatar
Default upgraded valvetrain with stock cams
This may seem like a dumb question, but I just want to verify that this is OK.
I'm rebuilding my head with Omnipower dual valve springs, valves and Ti retainers, but for money reasons, I may not be able to get my cams (BC spec III+) and cam gears for a couple more months. Logically, it seems that weaksauce cams would be OK with more capable valvetrain, but I just want to make sure. Its fine to put my B16A cams back in for the time being, correct?
TIA
Old Jul 20, 2005 | 04:29 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: upgraded valvetrain with stock cams (white_n_slow)
yes, it will be fine.
Old Jul 20, 2005 | 04:45 PM
EM1B18-R's Avatar
it will be fine, but you can actually lose a bit of power this way. the springs are stiffer and create more drag on the whole valve train. without adding bigger cams to offset the drag you will actually see a slight decrease in power and responsiveness. nothing you will be able to feel most likely, however.
Old Jul 21, 2005 | 04:46 AM
ITRnorway's Avatar
Default Re: upgraded valvetrain with stock cams (JoeB18-R)
when going to that setup would that reqire a dyno run or would a wideband & apexi do the job?
Old Jul 21, 2005 | 01:52 PM
EM1B18-R's Avatar
Default Re: upgraded valvetrain with stock cams (CRXnorway)
wideband on a dyno is best by far.
Old Jul 21, 2005 | 02:58 PM
Alright, thanks!
Danny Fallas
Feb 13, 2013 03:30 PM
406Honda
Aug 23, 2010 12:25 PM
Sabres_e
21
May 15, 2010 12:50 PM
1320king
Jan 1, 2008 08:44 AM
Mr.Meowsome
24
Oct 29, 2007 10:01 PM
