chassis stifness
Old Jul 20, 2005 | 02:24 PM
usafa2010's Avatar
Default chassis stifness
I was just wondering on the 94-2001 integra is there any difference between chassis stiffness in rs, ls, gsr, and type r
Old Jul 20, 2005 | 02:44 PM
mrdeadman's Avatar
They let me pick
Default Re: chassis stifness (usafa2010)
no, the gsr has a strut bar though its small and the itr has a bigger rear anti sway bar along with a strut bar.
Old Jul 20, 2005 | 02:58 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: chassis stifness (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">no, the gsr has a strut bar though its small and the itr has a bigger rear anti sway bar along with a strut bar.</TD></TR></TABLE>
The Type R is quite different. The entire rear section is reinforced (wheel wells, frame sections, rear lower arm tie). You can find this in a search.
The GSR, RS, LS, and GS are all the same chassis.
Old Jul 20, 2005 | 04:43 PM
usafa2010's Avatar
Default Re: chassis stifness (Dogginator)
I did search and couldent really find what I am looking for. So if I were to get an ls chassis it would be the same as a gsr in stiffness, for instance the gsr does not have extra welding in it to help re inforce the body. and IF i were to get an ls chassis and seam weld the frame would this increase the stiffness to the equilivent of a type r
thanks
Old Jul 20, 2005 | 04:50 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usafa2010 &raquo;</TD></TR><TR><TD CLASS="quote">I did search and couldent really find what I am looking for. So if I were to get an ls chassis it would be the same as a gsr in stiffness, for instance the gsr does not have extra welding in it to help re inforce the body. and IF i were to get an ls chassis and seam weld the frame would this increase the stiffness to the equilivent of a type r
thanks</TD></TR></TABLE>
I'm sure that seam welding the chassis would help with the stiffness. However, I doubt that the extra welding would increase the chassis stiffness to that of the Type R.
The Type R also has wider rear wheel bearings.
Check these links:
https://honda-tech.com/zero...66762
http://autopedia.com/Acura/97_TypeRChassis.html
IntegraPrez
Oct 9, 2004 09:08 AM
khmy2nr
15
Sep 30, 2004 07:07 AM
jaM3s Bond
Apr 7, 2003 06:11 PM
MooreBoost
Mar 16, 2003 10:53 AM
RacerXintegra2k
Sep 29, 2002 04:42 PM
