i have a 96 ek with 00 Si under dash harnes triying to put ls motor
Old Jul 20, 2005 | 02:03 PM
00eksi's Avatar
Default i have a 96 ek with 00 Si under dash harnes triying to put ls motor
« Re: i have a 96 ek with Si under dash harnes triying to put ls motor (00eksi) « » 2:15 PM 7/19/2005 Reply Edit
but its not working im running obd2 sohc vtec engine harnes and ecu and the ls motor chokes at around 3-4,000 rpms what kind of harnes should i use to run the 98 ls motor
Old Jul 20, 2005 | 04:00 PM
EE_Chris's Avatar
Default Re: i have a 96 ek with 00 Si under dash harnes triying to put ls motor (00eksi)
Put ALL wiring back to stock. You will use your stock harness for this swap. You'll need to extend some wires, but that's about it. Check the link in my sig for more information.
FTNW
Dec 3, 2011 01:48 AM
cxhb
Sep 6, 2005 10:15 PM
00eksi
Jul 19, 2005 01:15 PM
