slim fan install help
Old Jul 20, 2005 | 12:27 PM
coupon's Avatar
Default slim fan install help
i know this is pretty simple but just making sure i do it right
just wire up the blue wire to the blue wire off the harness and vice versa with the black wire?
after you mount the tabs, does it matter which way you stick the zip tie thing through?
what is the tape for?
what is the last hole on the tab for?
Old Jul 20, 2005 | 12:51 PM
jp8900's Avatar
Default Re: slim fan install help (coupon)
I just installed them through the radiator using those zip ties... You pretty much can pick which hole you want to use and cut off the excess or just leave it on for less of a hassle. BUt yes you connect the wires like mentioned unless you are installing them as pusher fans as i did. Then you will just switch wires. Hope that helps you out..
jon
Old Jul 20, 2005 | 12:54 PM
coupon's Avatar
Default Re: slim fan install help (jp8900)
Old Jul 20, 2005 | 01:53 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
where did u get that fan from?
Old Jul 22, 2005 | 04:37 AM
MikeD718's Avatar
Default Re: slim fan install help (rukawa1one)
How many forums are you gonna post this in?
coupon
Jul 24, 2005 08:21 AM
coupon
Jul 24, 2005 07:55 AM
coupon
Jul 21, 2005 07:16 PM
coupon
Jul 20, 2005 04:26 PM
coupon
Jul 20, 2005 02:14 PM
