IM ALMOST DONE WITH MY SWAP!! just need a little more of help
alright the motor is in the car and all the cables, hoses and most of the wiring is done... ive also topped off all of the liquids except for the transmission fluid... where do i fill it up at? anyways i need to know how to depin some of the connectors at the ecu... i have the diagram from rywire but i need to know exactly how you depin something... also i seem to have forgotten where some of the wires go... can someone post up a picture of all the wiring on the left hand side of the engine right above the tranny... thanks a lot
-Josh
Modified by Crimson_Tide at 2:17 PM 7/20/2005
-Josh
This is a general guide, I would purchase the actual Honda manuals for whatever parts you may have (i.e. b16a obd2 US emission engine ---> 00 Civic si Honda wiring diagrams.)
http://tech.hybridgarage.com/
This link is for 88-91 civics. Good dpfi to mpfi conversion guide
http://fourthgenhatch.com/mpfi.html
i looked but neither of them helped... i need to know where to hook up my starter and if i can just ground it out ot the chassis... thanks
-Josh
-Josh
http://www.ff-squad.com/tech/w...l.jpg
Thats for OBD1- its the same for OBD0 im guessing. The transmission fluid can be filled by popping out the cable VSS sitting on the top of the transmission. Unscrew and pull the VSS and fill there. Make sure it doesn't get overfilled by removing the overflow bolt on the bottom. When it starts leaking, then you've put in enough. You should be putting in 1.8 qts of transmission fluid.
-Jon
-Jon
ITR607
Sep 14, 2002 03:38 PM
